ZC dyno & compression test results
hey guys
just finished my DOHC ZC into '91 Civic Si swap (it still doesn't idle right!); here are the numbers:
114hp at the wheels
compression:
#1 145 psi
#2 150 psi
#3 150 psi
#4 140 psi
the engine is stock except for a K&N intake and a Airmass header. I figured I would get about
120 - 125 hp at the wheels with this combo, but it would seem that this engine is pretty tired, so on
to the rebuild portion of the swap...which I should have done in the first place.
114hp at the wheels
compression:
#1 145 psi
#2 150 psi
#3 150 psi
#4 140 psi
That is about right if you account for approx. a 14% drivetrain loss. The ZC came with 130 flywheel horsepower stock The intake and header don't really produce that much extra hp. Your compression numbers are pretty consistent.
[Modified by 91civic, 1:10 PM 10/15/2002]
91teg
Jan 16, 2004 12:06 PM
714phil
May 26, 2002 02:32 PM
compressin, compression, dohc, dyno, dynos, honda, hondazcheaderdynotest, motor, numbers, psi, results, stock, test, tester, zc
