Suspension & Brakes Theory, alignment, spring rates....
D-series axle and CRV outer joint
Old Jul 13, 2012 | 11:11 AM
Civic858's Avatar
Default D-series axle and CRV outer joint
I'm going to do a five lug conversion on my ek hatch using CRV front spindles (36mm hub). I'm still running the stock D16, will the stock D series axle shaft work with a CRV outer joint? I've heard B-series axles work but I won't be swapping the motor for awhile. Thanks.
Old Jul 13, 2012 | 01:28 PM
grumblemarc's Avatar
The Grumpiest
Default Re: D-series axle and CRV outer joint
I don't see how that would work. You couldn't use B-series axles on a D-series, as far as I've read, so how could you use the outer?
Corksil
Nov 3, 2011 08:29 PM
grant97teg
Jul 1, 2009 09:10 AM
integrawow
Apr 26, 2007 08:41 AM
nickeynick
13
Dec 7, 2006 03:39 PM
All_Motor_Moh
Mar 15, 2006 10:07 PM
