Car won't start and seems to have a ghost in the system
I just swapped my 93 del sol Si over to a 98 jdm b18c spec R, I utilized my obd1 harness and soldered on the injector clips, distributor clips, and alternator clips from the RHD harness. Injector wiring was plug and play, distributor I just matched positions in the clip with the position in the other clip and ignored colors, and alternator I did this pattern,
black with yellow stripe = black with yellow stripe
white with blue stripe = white with blue stripe
white with red stripe = blue wire
white with green stripe = white with yellow stripe
When I try and start the car, it does not crank and I can hear a clicking sound from the battery, (I had the starter tested and it tested good) but here is where it gets weird, if the key is in the on position and I press on the throttle at any position, the instrumental cluster goes haywire, the oil, engine and battery lights will flicker on and off, and the mph will jump from 0 to 10, although the car is not on or moving. I figure it must be a wiring issue. I have looked all over and made sure all grounds were connected but to no avail.
I have even tried switching my chipped obd1 p28 to a obd1 (p72?) as well as the battery and nothing changes.
Any help will be appreciated.
Check your main grounds, [batt. to chassis, chassis to engine] check the thermostat grounds, in fact check all your grounds.
When one circuit has an effect on an other seemingly unrelated circuit it is almost always a ground related problem, grounds are the one thing that all circuits have in common. 94
Alex Preece
Oct 3, 2018 07:36 PM
6doorsentra
14
Jun 18, 2017 12:41 PM
TehMan
Sep 12, 2008 06:54 AM
white4doorsi
Apr 29, 2008 06:45 AM
