FS: Garage sale blowout - Pictures of everything (OE Honda, Spoon, Bride and more!)
numbers for everything so you can verify what it is and what it's for.
The parts are located near Reading, PA. Shoot me an email with any questions you have - snoborder87@gmail.com - and I'll get back to you as soon as I can.
UPDATE (08Oct2012): Prices lowered!
BRIDE Stuff
1. BRIDE Seat Rails Civic EK - Drivers Side - ($140)
2. BRIDE Seat Rail Adapter Hardware - FO Side Plate - ($50) - 1 set of these - 1 set is SOLD
2. Bride Zeta-III Type-L (Large size) - gradient fabric - SOLD
3. Bride Head pad - SOLD
SPOON Stuff - GONE
1. 78512-AP1-000 - Spoon Steering Boss - SOLD to mikesaba
2. Spoon 5-Spd Duracon shift **** - SOLD to silverstreek81 on H-T
3. Spoon reservoir covers - SOLD to silverstreek81 on H-T
4. Spoon Steering Wheel - SOLD to mikesaba
Other parts - Wheels/Tires/Brakes/Suspension/Engine
1. D2 Lower Control Arms - EK - ($130)
2. Mugen lug nut set - SOLD to felipe on NWP
3. Stop Tech Performance pads - 93-00 Honda Civic DX/LX w/ Rr Drum Brakes - ($50)
4. Energy Suspension shifter bushings - B-series - SOLD to silverstreek81 on H-T
5. Works Bell Rapfix Quick Release Spacer - SOLD to spork
6. PasswordJDM Kevlar Intake EK - PWCPC-EK9-BSK - ($150)
7. Innovative Motor Mounts - SOLD to alex eg hatch on H-T
8. PowerSlot Rotors - Slotted - Most Civics - ($120 for both)
9. Competition Clutch Street Series 2100 - SOLD to joshd_bh
10. Password JDM Strut Bar - SOLD
11. Function Form Coilovers - SOLD
12. General G-Max AS03 - 205/45ZR/16 83W - SOLD
13. Polished Slipstreams - 16x7--4x100 - ET40 - SOLD
Turbo D-Series Stuff
1. 37820-P05-A01 - OBD1 P06 VTEC ECU - SOLD
2. RyWire Jumper harness - OBD2A to OBD1 (For 96-98 EK) - ($40)
3. PFab Turbo Manifold - D16 with T3/T4 flange and external wastegate - never used, just needs to be cleaned up a little bit - A/C COMPATIBLE ($220)
4. Stealthmode Performance oil line kit - D-Series with T3 - may work with others - ($50)
5. D16 blockguard - ($40)
6. YCP Pistons - 'Vitara' Pistons for D16 - ($100)
7. Hastings Piston ring set for Vitara Pistons - ($35)
<br /><br />
<br /><br />
BRIDE Stuff
SPOON Stuff - GONE
<br /><br />
<br /><br />
OE Honda Parts Section
1. 19502-P30-000 - Lower radiator hose - SOLD
2. 19501-P30-000 - Upper radiator hose - SOLD
3. 78125-S01-L01 - Tach assembly 99/00 SI - SOLD
4. 78130-S01-L01 - Meter assembly, fuel and temp 99/00 SI - SOLD to chad
5. 78115-S01-L01 - Speedometer assembly 99/00 SI ($110) -- Came with 1 mile on the odometer
6. 50842-ST0-N10 - Left/Front rubber stopper (EK M/T) - ($40)
7. 50841-ST0-N10 - Right/Front rubber stopper (EK M/T) - ($40)
8. 50825-S04-000 - Transmission mount bracket (All EK) - ($70)
9. 11910-P30-000 - Engine mount bracket (EK/DelSol) - ($50)
10. 90188-SR3-010 - Bolt 14x67 (EK) - I have 3 of these ($2.50 each)
11. 50827-S04-N10 - Rear engine bracket (EK) - ($40)
12. 91640-SM4-003 - Screw grommet - I have 2 of these - ($1.50 each)
13. 90302-SA4-003 - Spring nut - I have 2 of these - ($2.50 each)
14. 93913-14420 - Screws - 5qty ($1.50)
15. 90372-SR3-003 - 12mm Nut ($1.50)
16. 90504-SR3-010 - FR. Stopper Washer - ($2.50)
17. 90165-S04-000 - Flange bolt 12x97 - ($4)
18. 90131-ST7-000 - L. FR. Stopper Bolt - ($5)
19. 90133-S04-000 - R. FR. Stopper Bolt - ($10)
20. 38941-PR3-000 - Idler Bracket - EK - ($20)
21. 90190-SR3-000 - Flange bolt 12x64 - ($1)
22. 19511-PH7-003 - 36.5mm Hose clip - SOLD
23. 90505-SB2-000 - Side mounting washer - I have 2 of these - ($2.50 each)
24. 14400-P2F-A01 - Timing Belt - SOLD to Ser1N
25. 12251-P2J-004 - Head Gasket - SOLD
26. 17910-ST7-R01 - Integra Type-R Throttle cable - SOLD
27. 16411-P73-000 - ITR throttle cable bracket - SOLD
28. 15400-PLM-A02 - Oil Filter - SOLD
29. 38930-P7J-000 - A/C Compressor Bracket - SOLD to chad
30. NGK Wire Set - 99-00 SI - ($70)
31. 16010-S01-A32 - Fuel Filter - EK - ($20)
32. OE Spindle Nut - 32mm Axles - ($5 for both)
33. 17130-PM6-003 - PCV Valve - Civic/CRX - ($15)
34. NGK Plugs - Temp 7 Small Gap Copper race plugs - B-Series VTEC - ($15)
35. JDM Gathers CD Player - lights up amber - ($50)
can you pm me price of energy suspension transmission bushings, spoon duracon shift **** and reservoir covers shipped to 65336?
thanks!
thanks!
Thanks to everyone who has bought stuff so far. It's going out tomorrow morning.
Still plenty of brand new stuff left for the rest of you!
All purchases have been shipped out. Thanks!
Keep bumping this, I know someone needs these parts
ej1 - tried to send you a pm but your inbox is full. send me an email - snoborder87@gmail.com
Saturday night bump. Any purchases between now and Monday (EST) will be going out Monday morning
All parts sold have been shipped out, back to the top!
There's still have a bunch of good stuff here
