so i got a b20b swap and looking for parts for it
Old Jul 13, 2012 | 02:11 AM
deeboi's Avatar
Default so i got a b20b swap and looking for parts for it
just picked up an integ 91 with a jdm b20b swap and looking for the usual tune up parts at autozone like spark plug, oil filter, oil pan gasket, etc. but they don't know which engine to look up for this. i know it has a p75-4 head on it. just wondering which spark plugs, oil filter and other parts to get for this motor. been doing research and i think i got a good idea but want to post this question anyways. tia.
Old Jul 13, 2012 | 02:14 AM
deeboi's Avatar
Default Re: so i got a b20b swap and looking for parts for it
also the circles on the head says 9/6, 5, 3/1, 8. not sure what that last number means but i presume that it's a 1996 motor built in May. from my research i understand that this is from a 1996 jdm crv. would the usdm crv 96 have identical parts?
Old Jul 13, 2012 | 03:53 AM
Runnerdown's Avatar
"tune up parts at autozone"
Careful what you pick from there. Here is a list of where I would get the parts, and yes a 97-98 Usdm crv is the same.
Spark plugs: ngk oem spec plug, autozone should have this
Oil filter: purolator pureone is a good brand that parts stores typically carry
Oil pan gasket: oem Honda only
Distributor, plug wire parts: oem Honda only
And yes if the numbers say 9/6 on the left side of the head it was manufactured in that year, as for the other numbers I think they indicate the casting molds or plant numbers but I'm not positive.
Old Jul 13, 2012 | 04:03 AM
deeboi's Avatar
thanks..so i'll ask for parts list of a 97-98 usdm crv. also i know that the head is supposedly the same as the 96 integra ls head?
Old Jul 13, 2012 | 04:41 AM
Runnerdown's Avatar
Yes the p75 head is the same as the integras. This head is prone to valve seat issues so it's a good idea to do a valve lash adjustment as soon as you can. Grab a manual or there might even be a write up here on h-t
dELfONiK
Southeast (Sales)
Jan 11, 2007 10:41 AM
Repodevil
May 14, 2006 05:38 PM
gill_za
26
Sep 20, 2005 07:57 PM
01gizzer
Aug 4, 2003 03:51 AM
