Rear LCA Install
When I install my F7`s, what`s best practice when tightening the bolts? Do I torque them all the way when the car is up in the air on stands? Or do I hand tighten the bolts when it`s in the air, than torque them completely when the car is on the ground? Just something I`ve always wasn`t sure about.
Poly bushings do not need to be clocked.
however if you changed the ride height, I would loosen all bushing bolts, and clock them
EDIT-- Make sure you unhook the sway bars when doing it.
its good practice to tighten the bushings loaded, even if they are poly. there is more than a single axial movement in honda suspension, so just tighten it where it needs to be first.
using jackstands and a jack to do it properly is advised. not just on the ground.
besides, ive always found the rear LCA able to line up and bolted in to the trailing arm easier with it jacked up level.
incogNitto
Mar 17, 2002 06:02 PM
