CB7 Auto to 5spd Swap HELP!
Ok guys here is the question. I have searched and cannot find the exact answer i need.
I have a friend with a Automatic '90 Accord and we converted it to 5spd and has a H22a swap.
Everything is connected and ready to go. Grounds and all.. Does not start.
Is there a safety switch that needs to be bypassed since it was automatic?
Also what connections plug into those switches on the Clutch pedal?
Please any help! Thanks!
UPDATE i jumped one of the plugs and it cranks now... but still not getting any power to the distributor. There is another set of wires on a plug that used to go on the automatic shifter that I believe has to be jumped/bybassed to be able to start the car. If anyone can get me the schematics for those plugs that would be great!!!!
Here is a picture of the plugs
UPDATE: Found the issue
The car was originally setup for external coil. So we spliced together the external coil plug wires on the harness side and motor started right up.
EKSedAndy
10
Mar 16, 2011 01:58 PM
jwizzie2001
Oct 29, 2008 07:06 AM
