z6 vitara build. What rods?
Old Jul 12, 2012 | 10:16 AM
ch22ris's Avatar
Default z6 vitara build. What rods?
Not real familiar with the vitara builds but do you have to use a custom rod when you get these pistons or can you run some eagle rods? any information on the vitara builds would be great.. thanks
Old Jul 12, 2012 | 10:49 AM
skateboard_ej8's Avatar
im hench irl
Default Re: z6 vitara build. What rods?
Your best bet would be to go with the custom length I beam rods from fjt. Using eagle rods with those pistons will leave you with a ridiculously low compression ratio and sluggish engine response.
READ and CHECK this thread out for all your boosted single cam questions: https://honda-tech.com/forums/showth...4#post47601554
Old Jul 12, 2012 | 11:01 AM
wmac's Avatar
fj is on hiatus, don't know if he will return.
p2p0
http://www.ebay.com/itm/YCP-75mm-Vit...ht_3358wt_1012
or RC Autoworks for custom length,
or Eagles for 137mm.
Old Jul 12, 2012 | 12:14 PM
ch22ris's Avatar
p2p0
I saw the rc autoworks ones Im looking to do a 400 hp build are there any reviews on these rods?
Old Jul 12, 2012 | 01:28 PM
wmac's Avatar
both the RC-AutoWorks and P2P0 rods look remarkably like my og fj custom length rods.
either should be able to support 400hp easily.
Old Jul 12, 2012 | 06:16 PM
blackeg's Avatar
yeah the eagle rods in the z6 yield a compression somewhere in the upper 7:1 ratio. its pretty bad. even with a ton of ignition timing advance it sluggish out of boost but did boost up fine once you got on it. mainly just cruising around sucked id drive everywhere at like 8" vacuum and it took at least 5-8 mpg off what i though it should be.
get a custom length rod that gets your cr up high 8s to around 9 if possible
Old Jul 12, 2012 | 08:36 PM
bgdriver's Avatar
p72 rods and some heavy decking/milling can bring vitaras to 10+:1
Old Jul 13, 2012 | 03:47 AM
blackeg's Avatar
ahh interesting. the vitaras are still a cast piston though, and part of their extreme effectiveness is the lower compression ratio that they give. while the 7 something with the eagle rods is really too low, bringing it up toward 10:1 i feel starts to detract from using them in the first place
4.8t
May 4, 2011 10:10 PM
Mr. Em1
Feb 12, 2006 06:58 AM
hookups214
Jan 29, 2006 01:04 PM
quik sol
Aug 20, 2004 08:07 AM
