What axles will fit these setups?
Old Jul 12, 2012 | 09:21 AM
firejackal's Avatar
Default What axles will fit these setups?
Out of the many things I don't know, axles are one of them, maybe you guys can educate me.
This is the current set up... 91 crx hf.
I'm putting in a d15b2 ... I need to change the axles... to my understanding since i have the hf hubs, I HAVE to use hf axles? Or what all can fit this?
Next question, if I use the suspension parts out of my 90 teg ls, including the hubs if needed, does that only work i I was going with a b series engine with b series axles?
thanks in advance, there needs to be a super swap guide for this stuff
Old Jul 12, 2012 | 09:27 AM
turbostd's Avatar
Default Re: What axles will fit these setups?
If keeping your hf hubs you would need hf or civic std/base axles, they have the smaller outer.
If using the da hubs you would use civic/crx si or dx axles.
Old Jul 12, 2012 | 09:30 AM
firejackal's Avatar
Thanks turbostd, I appreciate that information. now for more technical reasons on this; is it different spline count or is it the length? or does it all have to do with that smaller outer?
Old Jul 12, 2012 | 10:11 AM
turbostd's Avatar
outers are smaller. Axle length is all the same for 88-91 d series. I don't know about the awd shuttle/wagovans never messed with one of those
onemore
Jan 9, 2008 03:51 PM
SnakeBait
Jun 13, 2007 10:20 PM
pinecone
Mar 14, 2006 03:32 PM
Silent Knight
Jul 19, 2005 12:20 PM
whizdumb
Apr 11, 2003 07:56 PM
