JDM vtec D16A obd1 into 1990 civic si
Old Jul 11, 2012 | 01:10 PM
video_voide's Avatar
Default JDM vtec D16A obd1 into 1990 civic si
I will soon be swapping in this engine, which is equivalent to the USDM D16Z6, or so I am told. It will come with the P91 ecu. The car is being built with autocross in mind.
Here is my check list. Please add or make suggestions if you have any:
-- Rywirer OBDO to OBD1 package, which includes ecu jumper, distributor adapter, integrated vtec subharness
-- delete resistor box for OBD1 injectors. (Are the harness injector connections the same as OBD0?)
-- install new timing belt and water pump
-- use Si trannsmission (Is a lighter flywheel worth it?)
Here is where I am unsure…
Will the D16A6 engine mounts swap over? Should I splurge for Haasport mounts? I believe it will come with a MAP sensor attached to the throttle body. Anyone know? I believe it comes with a one wire O2 sensor. Are there any other sensors that my harness will not accommodate?
Pics will come later...
Old Sep 22, 2012 | 05:09 PM
redmondracing's Avatar
Default Re: JDM vtec D16A obd1 into 1990 civic si
i have a 93 civic ex with the d16a motor also i bought it this way but its already obd1 running on a p28 ecu which im thinking about changing and im almost positive the motor mounts will line right up!
HondaPartsHero
10
May 3, 2023 05:32 PM
video_voide
Jul 12, 2012 01:25 PM
dc5itracer
10
Mar 26, 2011 10:29 AM
got_speed
Mar 14, 2009 06:02 PM
CanadaCivic
Aug 13, 2002 03:05 AM
