Beginner Question
Old Jul 10, 2012 | 05:41 PM
Slobuild's Avatar
Default Beginner Question
i have an 89 civic hatch dx. Ive never done a swap and wanted to get a few oppions. Is a b16b swap to complicated for a first timmer, if so what would you recomend.
Old Jul 10, 2012 | 06:05 PM
93delsold16z6's Avatar
Default Re: Beginner Question
U have the base model d15 I assume. The si motor is good for a -20-30 hp gain. But you would need the si trans to feel the power also. What u could also do I what I have done to my dx. Just bolt up an so tranny. Feels way better than stock gas mileage will suffer tho bro series is a bit much for a beginner I would say unless u have experienced friends with you the whole time. All day series motor parts are exchangeable to a degree. Hope this helps
Old Jul 10, 2012 | 06:08 PM
Slobuild's Avatar
Thanks alot for the advice and yes it is a base dx. It has no motor trans or wiring harness right now. so i might just go the d series rout and save a lot of money and time.
Old Jul 10, 2012 | 06:26 PM
91EFH22's Avatar
Where are you located?
Old Jul 10, 2012 | 06:29 PM
Slobuild's Avatar
unfortunately i just moved to south dakota
Old Jul 11, 2012 | 03:40 AM
91 EF DX's Avatar
just remember that you will have to source a dx wiring harness bc the mpfi harnesses out of the others will not work with the cabin harness.
Old Jul 11, 2012 | 04:08 PM
CRX Toad's Avatar
Unfortunately this question is asked often. Please check the FAQ and utilize the search function. Thank you and welcome to the board.
JNunez87
Jul 6, 2016 05:53 PM
HybridB18Vtec
Mar 24, 2005 04:50 PM
manson
Aug 28, 2003 06:26 AM
2ndGenREX
Jun 5, 2003 07:37 AM
lilred92hatch
Mar 12, 2003 03:54 PM
