FS: BWR catch can/tank
Selling my catch tank it was never used only mounted up. It has 6 bungs. 4 can be used for your valve cover and the other 2 are for drain back. You can also use plugs and cap off an bungs you choose to not use. It also comes with 2 small K&N filters up top.
This will fit in a stock Honda or Acura battery tray.
I also have AN line and fittings if needed. As well as a valve cover with 4 bungs welded on it.
The Benefit of a catch can is to help reduce crank case pressure. If this isn't done it can cause premature wear on your engine/ head.
$275 plus shipping
NEVER USED!
Please txt 763-772-7592
Please make an offer.
$275 plus shipping
NEVER USED!
Luserkid
Nov 29, 2015 01:34 PM
Rikaro
Mar 11, 2009 01:25 AM
