94 accord shifting problem
Old Jul 9, 2012 | 01:16 PM
94lxaccordturbo's Avatar
Icon2 94 accord shifting problem
I am buying a 1994 honda accord lx for 300 off a friend.The car has a shifting problem ; it only shift into fourth gear. My brother thinks it's the shift linkage i haven't checked , but could that be the reason ? the car has 205,00 miles on it
Old Jul 9, 2012 | 01:30 PM
tim73's Avatar
Default Re: 94 accord shifting problem
Could be, or could be the clutch(Or hydraulics) or synchros.
Old Jul 9, 2012 | 02:13 PM
gary95H22Accord's Avatar
Sounds like you need a new tranny. Not a bad buy for $300 though. Pick one up at a junkyard for cheap
Old Jul 9, 2012 | 02:18 PM
I was thinking the trany to and orginaly the guy wanted 950 for the car. is there anything else that it could be ?
Old Jul 9, 2012 | 04:38 PM
Hidenplanvew's Avatar
I would say clutch.. Can you shift it into any gear with the engine off?
Old Jul 9, 2012 | 07:31 PM
yes you can switch into gears when the car is off
Old Jul 29, 2012 | 12:01 PM
can anyone tell me what it is
Old Jul 29, 2012 | 12:16 PM
doctorbee's Avatar
Does it grind when you try to shift into anything other than 4th? if so it could be synchros. best thing to do would be to get a junkyard tranny and replace all the seals on it before you swapped it in with a new clutch.
Old Jul 29, 2012 | 12:51 PM
no it doesn't grind when you shift into fourth a part near the shifter is bent i will try to take a pic of the part and the car
Ef4doorwagon
Nov 28, 2014 10:17 PM
Bizarre
Feb 20, 2006 05:46 AM
AmonDin
Mar 17, 2005 04:58 AM
vtec fan
Sep 13, 2003 11:08 AM
89civichatchback
13
Jul 9, 2003 11:23 AM
