k-series race car part out..Turbo Kit..built k24.. race car shell etc
Old Jul 9, 2012 | 12:51 PM
b20-type-r's Avatar
Default k-series race car part out..Turbo Kit..built k24.. race car shell etc
Will update with more parts soon.**
JDM Teg Cf Hood With Aero Catch Hood pins- 400 SOLDDDD
k-series Golden Eagle Polished Fuel Rail - 80
Auromotive Fuel pressure regulator - 100
Racetronix fuel injector driver Box 120 reg250
fuel injector clinic 1650cc low inpedience Injectors -350
Hondata 4 Bar Map Sensor - 60
AEM 3.5 Bar map sensor 50 psi 150
AEM Wideband w/ mount for top of sterring whee. comes w/boxl- 180
type S o2 Sensor like new - 120
Hybrid Racing eg/dc k-series Convertion harness - 160
02-04 type S sub harness - 120
Type S shifter Box + cables 140
Hasport polished k-series eg/dc mounts 350
K_tunedRad + Slim Fan - 220
Hondata K-pro PRB w/Box, cables & software with product # - 1000
K-Tuned eg/dc Traction Bar - 200
RCI 5 point Racing Harness - 60
driveshaft shop K-series eg/dc 2.9 axels (475 hp) - 500 reg800
Fuel system ---- Full blown Billet Dual Walbro Pump hanger.. selling with 2 Walbro pumps.. all Fittings. Russell - 8 Braided line with Fuel Filter & Relays. Made 600whp with this without any issues. http://fullblownmotorsports.com/perf...al-pump-hanger
$450
B]Shell[/B]
1994 Acura Integra LS rolling shell
comes with;
PIC apex suspension 10/8k
Blox Lower Control Arms
ASR Brace
Skunk 2 Pro Upper Control Arms
gsr dash
JDM Type R Wheel
Jdm Type R cluster
USDM BLack Type R Seats
DB8 Rear type R seats
DB8 Door Panels
4pt Chromoly cage
Db8 Red Carpet
01 Jdm DB8 Type-R Front End w/ Black Housing headlights & HIDS
Golden Eagle Rear Bumper Diffuser
polished 15in rotas
cross drilled slotted rotors
new break lines
3500 can also nagotiate a lower price with some parts removed,
Complete stage 5 K-series Turbo Kit
K-Series Sidewinder Manifold
Tial 44mm Wastgate w/ VBand
stainless Wastegate DumpTube, With V Band Clamps & Heat wrap
custom Air/Air Intercooler 31 X 11.75 X 4"
All Intercooler Piping Couplers, and T Bolt Clamps and Vacume lines
Aluminum Intercooler Piping w/ Flange for BOV
Tial 50mm Blow Off Valve
Precision Billet 6262 Turbo With all oil fittings & Vband.
-10AN black braided Oil Return Line
-3 Oil Feed line with Block and Turbo Fitting's & heat wrap tape.
Stainless 3 inch down pipe with V Band Clamps w/ Heat Wrap
Boost Controller
Boost Gauge
Everything like new with no short corners taken, everything in perfect working condition. Made 600whp with this kit with no issues.
came out of a DC.
* Injectors not included*
$3000
The motor was built by Gram @ canadian cylinder head. Was built for track purposes, only got around to making a few passes on it. yielding a personal best of 10.68@141 w/ a 1.88 60". Tuned at 27 psi made 600whp 430tqe. Motor is still in the car and runs perfectly. Only Royal Purple oil changes. can provide buyer with a tune as well if needed.
Built K24/K20 Motor
k20a2 head
k24a2 Long Block
crower rods(800 hp) w/ Arp rod bolts
cp pistons 9:1 compression
Fully blueprinted and Balanced Crank
Arp Rod Bolts
ARP Main Studs
Arp Head Studs
ACL Race Bearings
Cometic Head Gasket
rbc intake manifold + hondata gasket
k20a2 Tb + all sensors
Karcepts TB adapter
Ep3 Idle Pully
K20a2 Cams
SuperTech Valve Springs
SuperTech Retainers
Ferrera Valves
k20a2 oil pan
k20a2 oil pump
k20a2 oil pan tapped with -10an
all new seals, timing chain, guides, tenshioner , 87.5m bore etc.
$4000
Ep3 Tranny with 4.7FD & WaveTrac LSD
$800
Old Jul 10, 2012 | 09:51 AM
wookiemaddness's Avatar
Default Re: k-series race car part out..Turbo Kit..built k24.. race car shell etc
Bump for you.
Old Jul 28, 2012 | 11:15 AM
tunedX's Avatar
Selling DB8 Rear type R seats??
Old Oct 3, 2012 | 10:30 AM
vd9172505's Avatar
pm'd you, if you are still parting out
Old Oct 3, 2012 | 01:21 PM
b20-type-r's Avatar
solddddddd
lsvtek
Northern California (Sales)
Apr 7, 2014 04:31 AM
ECKOTYPER
Aug 31, 2009 12:18 PM
y0heezee
Aug 25, 2009 10:19 PM
ECKOTYPER
Aug 17, 2009 03:30 PM
implayaz9
Mar 9, 2009 07:18 PM
