using hf block with a6 head....comp. numbers??? is it possible?
Old Oct 15, 2002 | 05:00 AM
SohcVtecCrix's Avatar
Default using hf block with a6 head....comp. numbers??? is it possible?
i have heard that the hf bottom couldnt be used with an a6 head swap. but i have also heard that the hf bottom is the higher compression than the d15b2.....so can i use the hf bottom, and if i can, what will the comp ratio be like?
peace
Old Oct 15, 2002 | 06:58 AM
CimorelliCRX's Avatar
Default Re: using hf block with a6 head....comp. numbers??? is it possible? (SohcVtecCrix)
The problem is that hte valve releifs on the piston only supper two valves rather than 4 valves like a DX or SI bottom end. Some people said that it dotn some say it do, the only way to know for sure is to find out for yourself basically.
Old Oct 15, 2002 | 07:10 AM
89 CRX SI's Avatar
Default Re: using hf block with a6 head....comp. numbers??? is it possible? (CimorelliCRX)
get a A6 block worth the 100 dollars or less.
the d15b2 block has only 2 valve reliefs as mention above. I dont think u wanna spend money on getting other ones machined in.
gnar kill
Mar 22, 2006 07:40 PM
dod
Mar 20, 2006 08:15 PM
civiccrx21
Apr 28, 2003 02:55 PM
iwouldHITit
12
Dec 30, 2002 07:40 PM
crxfanatic
Apr 29, 2002 10:11 AM
