can i use exedy khc05 instead of 13?
ok so i live in japan and have a type r so its b18c5, i need to replace my clutch soon so might as well do everything at once. I was seeing that i need the exedy khc13 based off there website but i can get a better deal on the khc05. the only difference is one clutch disk has an outer diameter of 219mm while the khc13 had a diameter of 210mm. Can i use either one? both kits comes with pressure plate, flywheel bearing, throwout bearing and disk. thank you
Nextelbuddy
12
Jan 6, 2004 05:12 PM
