afr reading lower after adding velocity stack
Old Jul 7, 2012 | 04:08 PM
raverx3m's Avatar
Default afr reading lower after adding velocity stack
i just installed the v stack with k&n filter instead of autozone filter.
my afr reading was 14.7-15 when cruising
and 12.4-12.8 when open throttle
now its 13.9 -14.7 cruising
and 11.3-12.4 when open throttle
does that mean that whatever i did is getting me less air and choking the engine?
or can it be warmer weather?
i tuned it about 2-3 months ago when it wasnt very warm.
Old Jul 7, 2012 | 04:25 PM
grumblemarc's Avatar
The Grumpiest
Default Re: afr reading lower after adding velocity stack
Doesn't look lean to me. You added more air and now the ECU is dumping more fuel to compensate.
Old Jul 7, 2012 | 05:05 PM
raverx3m's Avatar
its open loop tune if i added more air wouldnt it be leaner because fuel maps are same and more air is coming into mixture?
also when decelerating i only see fuel cutoff when throttle is completely closed is that how it works? i always thought that fuel cuts off earlier than that.
weird thing innovative ships their units with a serial port when most of new laptops dont have the serial ports anymore...
i was gonna hook it up to my laptop to get a afr readings table but failed lol no serial port on any of my laptops...
Old Jul 7, 2012 | 05:12 PM
The Grumpiest
I haven't gotten into tuning yet so I'm probably not the best person to listen to. But I will say that I'm running richer with no changes made in my setup other than this heatwave.
As for the serial port, I know they have serial to USB adapters.
http://motors.shop.ebay.com/i.html?_...=serial+to+USB
Old Jul 7, 2012 | 05:23 PM
Dc4LsTeG's Avatar
EK9
Because the hotter the air the thinner. That's why its more rich in hotter weather
Old Jul 7, 2012 | 05:25 PM
The Grumpiest
Simple science. Nice, simple explanation. I like.
I had the erroneous idea that the ECU should totally compensate for this.
Old Jul 7, 2012 | 05:27 PM
Dc4LsTeG's Avatar
EK9
Im not sure but I believe it should some what as long as you are in closed loop but i'm not positive
Old Jul 7, 2012 | 06:10 PM
raverx3m's Avatar
i might be wrong but i think with a closed loop theres a target afr +/- certain %
and ecu will compensate for it. i ran the car with O2 enabled and afrs were leaner all the way across because ecu adjusts it.
but the engine didnt run as good as in open loop i might try to enable it now to see if o2 would help in hot weather.
i guess i should do a laptop datalog run with regular filter and with v stack to see if theres difference.
Old Jul 7, 2012 | 06:23 PM
doood's Avatar
been there done that
in open loop the ecu runs solely off the fuel/timing maps and doesnt take the o2 readings into account. you're right that in closed loop it will adjust but only so much.
those a/f readings arent too bad.
Old Jul 7, 2012 | 06:34 PM
raverx3m's Avatar
i was just trying to figure out if v stack made difference lol
but i guess i should collect some more accurate data to tell instead of guessing .
just wanted to confirm that warm weather does affect the readings.
Old Jul 9, 2012 | 08:07 AM
HCivExoo's Avatar
The temp. Humidity, Barometric Pres. they can all have effects and even fi you are in closed loop if you have it set to only a low percentage of allowable change from your base map it may not correct the mixture enough to see that same 14.7 you were seeing before
Old Jul 9, 2012 | 09:03 AM
raverx3m's Avatar
i want to enable my O2 sensor for summer time.
where in crome can i see the target afr and the percentage?
do tuners usually set that up when they tune open loop?
ekhatch66
Engine Management and Tuning
Aug 19, 2009 09:14 AM
R-Toyz.com
Jan 27, 2004 03:47 AM
