94 Del Sol - Just poked a hole in something important HELP!!!
Old Jul 7, 2012 | 11:32 AM
Ju1cesk8er's Avatar
Default 94 Del Sol - Just poked a hole in something important HELP!!!
So my friend's dumbass said he knew how to hook up some subs in my car.
Basically to make a long story short he ended up poking a hole in something by the battery and a hole bunch of gasses came out. Like freon or something. Please tell me what it is and what I need to do to fix it. if you look at the hole near the battery on the picture he drove a screwdriver through it and thats when a whole bunch of something sprayed out. HELP!!!
Old Jul 7, 2012 | 11:33 AM
Ju1cesk8er's Avatar
Default Re: Just poked a hole in something important HELP!!!
Sorry for the huge pics. I can never get them on the right way.
Old Jul 7, 2012 | 11:45 AM
grumblemarc's Avatar
The Grumpiest
What hole?
Old Jul 7, 2012 | 11:46 AM
Fnix's Avatar
cant see anything in the pics.... AC hoses? Fuel filter? DOnt touch or breathe in any of that AC freon
Old Jul 7, 2012 | 11:55 AM
Former User's Avatar
Picture resized. Figure out how either to take smaller pictures or to resize them on your computer. If you continue to post over-sized pictures, I will close your threads.
In all tech threads, you also need to mention what car you have. Not including this information will also lead to thread closure.
Replace the punctured refrigerant line, replace the receiver/dryer, and then pull a deep vacuum on the system overnight. If the vacuum holds (no leaks), then recharged the system with the proper weight of refrigerant.
Old Jul 7, 2012 | 11:58 AM
Jtisawesome's Avatar
From Freon gases I'm guessing not saying fershure but he may have poked out the ac hose but it could be anything
Old Jul 7, 2012 | 12:02 PM
Ju1cesk8er's Avatar
Okay. I have a 1994 Honda Del sol. Its the hole thats to the right under the battery. I'm trying to figure out where to run the power cables from the battery. I know it was freon now. I just want to know what he poked a hole in.
Old Jul 7, 2012 | 12:10 PM
The Grumpiest
Default Re: 94 Del Sol - Just poked a hole in something important HELP!!!
Freon only runs through one system. Think about it for a second and follow Ron's directions regarding the replacements.
siboosted's Avatar
if he went from the engine bay into the car then its in the ac evaporator box behind the glove box. you will need to remove that and inspect the parts inside of it.
Old Jul 7, 2012 | 12:15 PM
This^ is also possible.
Remove the battery and take another (smaller) picture to post. Mark the hole where the screwdriver was pushed through and where refrigerant sprayed.
Old Jul 7, 2012 | 01:05 PM
SirProject's Avatar
its most likely the ac evaporator core. the other thing behind that would be your heater core and then youd be pissing out coolant. so most likely ac. your probably gonna need a new ac box
Old Jul 7, 2012 | 01:51 PM
Hidenplanvew's Avatar
Your friend is a epic fail
Old Jul 7, 2012 | 02:18 PM
gzes's Avatar
How did he poke it. dont yall just plug the the amp wire to the battery..... Dumbass buddy u got
Old Jul 7, 2012 | 04:03 PM
motegicivic's Avatar
Are you talking about the black grommet on the firewall next to the battery?
Behind that might be the Expansion valve for the AC.
Old Jul 7, 2012 | 06:10 PM
Ju1cesk8er's Avatar
I know guys what an idiot. I'm just as dumb for letting him. The orange circle is where the screwdriver punctured. Right where the black circular washer is.
Old Jul 7, 2012 | 06:13 PM
Ju1cesk8er's Avatar
Is that pic too big? If so I'll remove it.
Old Jul 7, 2012 | 06:14 PM
Ju1cesk8er's Avatar
Tell me about it.
Old Jul 7, 2012 | 06:46 PM
Perfect
Old Jul 7, 2012 | 06:53 PM
Ju1cesk8er's Avatar
Sweet! I'm finally getting the hang of this forum thing.
Old Jul 7, 2012 | 07:35 PM
Axatax's Avatar
If he would have just removed the battery he would have found an existing hole about two inches away from the "new" one.
Old Jul 7, 2012 | 08:24 PM
Ju1cesk8er's Avatar
So AC evaporator box it is?
Old Jul 7, 2012 | 09:43 PM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
^ Yep. As a bonus, tell your friend you want to upgrade to an Evap box with a cabin filter. What better time? Check my DIYs for the how-to in sig. I presume he's paying for the fix, yes?
Old Jul 7, 2012 | 10:16 PM
FrodeyEJ1's Avatar
willing to bet the always regretted "nah man its cool i know you didnt mean to" was said
Old Jul 7, 2012 | 10:45 PM
Ju1cesk8er's Avatar
Sweet. Might as well since I'm taking it out.
Lol It was more like "You Stupid MF!! YOUR PAYING FOR THIS S***!!!"
He sure as hell is.
Old Jul 8, 2012 | 07:13 AM
Might be the expansion valve for the AC, if you saw a greenish fluid. Does the AC still work?
I have used that grommet myself without an issue, all he had to do was take off the grommet poke a hole in it put the wire through and then the wires would of just slide down.
