98 ex Misfiring
Old Jul 6, 2012 | 02:01 PM
00E46's Avatar
Default 98 ex Misfiring
ok so the car burns a decent amount or oil.
i had to change the spark plugs after 12k miles cause they were so blackened they were misfiring. so i put the new ones in and they are fine for couple days then misfires again. i pulled them to check but they didnt look too dirty. no CEL. i was told it could be the piston rings leaking bad and choking out the plugs. seems to only misfire when in 2nd and 3rd at higher rpms
replacing the piston rings is outta my league and was quoted around $3000 witch blows cause i only paid 2500 for the car 2 years ago.
any ideas on misfire? thanks
Old Jul 6, 2012 | 02:11 PM
grumblemarc's Avatar
The Grumpiest
Default Re: 98 ex Misfiring
Full tune up and check timing.
Old Jul 6, 2012 | 02:18 PM
00E46's Avatar
i did the plugs, wires, distributor cap and rotator, fuel filter, all belts including timing 12k miles ago. just did plugs again
also idles fine and revs in neutral fine. just bucks when accelerating
Old Jul 6, 2012 | 02:26 PM
motegicivic's Avatar
Ever get a misfire cel?
What are the miles.
Do a compression check, see if one cyl is down or low.
Might have a bad valve since your burning oil.
3 grand is crazy you can get a rebuilt engine for $1200, then have it installed.
Or get a low mileage swap for say 600 bucks and then have it installed.
Old Jul 6, 2012 | 02:30 PM
roc0487's Avatar
Check ignition coil, and fuel injectors.
Old Jul 6, 2012 | 02:40 PM
00E46's Avatar
What are the miles.
192,000 miles
i was told it might just be a bad valve by one mechanic, gonna do a compression check tomorow just to see the numbers
gotta friend comin over we are gonna check for spark(i need to get a multimeter). i've never checked fuel injectors before.
Old Jul 6, 2012 | 02:47 PM
peterJDM's Avatar
$3000? You can get a full ITR swap with tranny included for that price! Also, if your car is burning oil AKA smoking BLUE smoke, a tune WILL NOT fix it because it is engine related and nothing the ECU is capable of fixing. The only way to make your engine stop burning oil is to FIX THE ENGINE.
Old Jul 6, 2012 | 04:05 PM
00E46's Avatar
heres a funky thing, i dont see any smoke coming out of the exhaust. i was behind a civic like mine the other day, it almost looked like they seafoamed the poor thing.
it is getting spark on all 4 cyl.
Old Jul 6, 2012 | 05:20 PM
Do the compression check, also do a wet compression check on the low cyl if one comes up low, just squirt some oil in that spark plug hole and redo the test on that cyl, if it is low it is the rings.
I am betting a bad valve, as for not seeing the smoke typically it will be at start up with bad valves. I have the same problem.
BTY if you are getting fouled plugs might be the rings, are the plugs wet or just carbon-ed up?
Old Jul 6, 2012 | 06:00 PM
00E46's Avatar
plugs are dry. cyl 3 is the worst. the 1, 2, and 4 arent too bad
a bad valve would burn as much oil as this does? well those would be much easier to fix than having to replace the whole engine.
Old Jul 6, 2012 | 06:59 PM
Former User's Avatar
As mentioned by another member --> COMPRESSION TEST THE CYLINDERS. Do the test after the engine has been warmed up. Then repeat after adding a tablespoon of oil to each cylinder.
Post the numbers (PSI) and go from there.
dwm2563
Honda CR-V & Element
Oct 23, 2014 12:00 PM
96civic909
10
Oct 15, 2008 05:54 AM
sickofitall1113
Jul 31, 2007 12:47 PM
JDMlyfestyle
25
Jan 20, 2004 01:11 PM
Digital-R
Aug 3, 2001 11:07 AM
