Transmission coolant plug
My 91 Accord has been leaking coolant (not from the radiator or hoses) when hot and overheating. I've tracked it down to a small bolt/plug (guessing 10mm) on the face of the transmission viewed from the passenger wheel compartment. It's clearly spurting coolant (not transmission fluid) out of there. I'm guessing that it is a drain plug for coolant that circulates through the transmission. Before I unscrew that plug (and accidentally drain all the transmission fluid) do I have it figured out?
Is there an o-ring or some other seal behind it?
The fluid that goes through the bottom of the radiator from the transmission is NOT coolant, it's auto transmission fluid.
dk127
Apr 24, 2007 09:01 AM
vtecpoweredsol
May 19, 2005 11:20 PM
camera obscura
Jul 13, 2004 06:04 PM
xavior66
11
Jan 21, 2004 01:27 PM
