1982 Honda Ascot FT500 *slow build*
the need to start a thread has finally hit me as 1- i havnt found another as modified online and 2- for motivation from others
i picked up my ascot from the second owner his uncle was the first and he had learned how to ride bikes on it (so its not perfect) he also had a 2000 yamaha 650 cruiser with rod knock i offered him a trade my labor for his ascot and 2 weeks later he accepted! he had no idea of my intentions and was a little sad the first time he saw the bike but now cant wait to see it finished either
so far i have installed
04 gsxr swingarm and mono shock-gift
01 gsxr inverted forks-gift
04 gsxr wheels-gift
01 gsxr rearsets-gift
future plans include finishing it as i still need alot of little parts and dont really have the cash
on with the pics although i didnt take enough
how it started out
test fitting the swingarm/rear wheel
front end installed which involved pressing out the steering stems and modifying the ascot stem to fit the gsxr lower triple (note hammer for rear shock)
i had started to take a few more pics at this time here a few of the rear shock install
top mount
lower mount
both mounts (shock removed for welding)
ride height after shock install
plate brackets for rear sets (both are the same)
right side on
right on the ground
and left on the ground
hope you like it so far like i said i still need stuff like clipons,upper triple,passenger pegs,my sprockets,chain (going to gsxrs 525),rectangle headlight,front and rear rotors,brake lines and the list goes on im sure this build will take a while as im already 10 months into it but check back if you like what you see!
04 gsxr wheels-gift
how it started out
top mount
lower mount
right side on
right on the ground
I am sad that you had to chop up and alter a pretty nice vintage Honda motorcycle, but it looks like it's going to come out well in the end.
It won't ever be original again though.
i have been slowly working on the bike this last week and got a few more things accomplished and took a couple pictures along the way
i mounted my passenger pegs
right
left
connected my factory header to my m4 titanium muffler(gift)
pipe tacked up
and welded
installed
i also welded my front sprocket up as i need a 3/8" offset to run the 180mm rear tire
and a picture of where it sits today i also switched out the front end with a 07 gsxr 600 front (also gift)for the radial brakes and it came with a top triple which i didnt have with the 01 1000 front was easy as pressing in my custom gsxr/honda ascot stem i made for the original front end
hope you enjoy the update!
right
left
pipe tacked up
and welded
installed
So... What's going on with this bike build? I'm interested in learning more. I'm in the process of building an FT500 myself. I'm not modifying it as extensively though. I'm wondering if you plan to gusset or reinforce the upper shock mounting position? I'm familiar with that frame tube & I'm almost certain that it will either bend or twist under the suspension load the way that you have it now. Here is a link to "Superior Sprockets" http://srs6.com/index.html They can build you an offset countershaft sprocket that is Balanced properly.
Good luck
~JM~
Good luck
~JM~
Last edited by toyomatt84; Oct 20, 2013 at 05:54 PM. Reason: Removed advertisement for outside forum.
I think you would be best served mounting a plate that allowed that rear shock to bolt in parallel to the ground as it is designed to be used.
the bike is in my garage in the same state it was in my last post. I am not worried about that tube,if I were I would have done it differently this isnt my first one
