ITR 4.785 final drive kit, carbon synchros, skunk2 and brian crower camshafts, cp pi
Old Jul 5, 2012 | 06:55 PM
pls52202's Avatar
Default ITR 4.785 final drive kit, carbon synchros, skunk2 and brian crower camshafts, cp pi
Tang
Text me for questions 828-638-8630
Im paypal verified pls52202@yahoo.com
Was waiting till December to post these items but maybe some of u need theses now.
http://www.carolinahondas.com/honda-...#post776590296
4.785 final drive with itr 1st gear $400 with ur 4.4 on top or $500 without.
Jdm 4.785 lsd with hybrid gears rebuilt with new bearings, seals and carbon synchros, $2000 will take tranny trades plus cash. If u make 200whp i personally guarantee u 12sec.
Skunk 2 tuner 2 new $550
Mfactory custom gears 150-350 depends what u want
U can get the most power out of just the transmission. 50 to 150+whp difference. For less than $400
"Its like this. If ur car can only top out at 105-110mph all motor in a 1/4 mile than why would u need a gear that top out at 120-130mph. We can take the power ur not using which is the difference between 110mph-130mph and move it to a usable rpm. And get u to ur top speed faster
Ls 5th gear set $125 - and $100 extra for install
Skunk 2 valveaprings and retainer new $350
Brian crower camshafts. Stage 1 or 2 turbo cams and stage 2 NA CAMs $420 each
Garrett 60-1 stage 3 turbo rated for 550whp $500
Cp 75.5mm pistons ceramic top coat and teflon side $500 "coating alone cost $200"
Probe 81.5 mm pistons new $350 no rings 11:1-12:1 compression
Wiseco 82mm 10:5.1 - 11:1 compression. Used but in exellent shape $275
Special 15% off all synchrotech product if i install and 10% off if u install. Synchrotech - Honda & Acura Transmissions
Old Jul 5, 2012 | 08:00 PM
90lsvcrxva's Avatar
Default Re: ITR 4.785 final drive kit, carbon synchros, skunk2 and brian crower camshafts, c
Love to have that 4.7 final drive. Free bump....
Old Jul 8, 2012 | 09:08 PM
Xtream_V's Avatar
Bump for you cause I was lookin to get another 4.4.. I'd be all over that 4.7 if I was staying NA tho
Old Jul 9, 2012 | 02:29 AM
pls52202's Avatar
That part is always over looked. The 4.7 its perfect for turbo. In a gsr tranny with the 4.785 final drive, 4th gear will top out at 127-135 mph depending on ur tires size. So unless u make over 600+ whp you will definitely benefit from it. Remember u want ur gears to setup around ur best 1/4mile speed. And get to that speed as soon as u can.
Old Jul 11, 2012 | 07:32 AM
pls52202's Avatar
Turbo cams gone. I'll pay half of shipping up to $15
Thrillhouse
Jun 29, 2004 11:41 PM
ViperbitGSR
Mar 14, 2004 03:04 PM
limlaboneout
Feb 8, 2004 10:31 AM
DaX
Sep 23, 2003 05:53 PM
joedr
Aug 30, 2001 12:25 PM
