93 si B series build thread
So I started askin for ideas awhile back and my thread to into a build.
So now here's my current setup this year aiming for more to come.
Bottom end:
B18a block
81.5 RS Machine pistons PR3 replica
Clevite bearings
Stock ls crank, micro polished
Stock Rods
ARP rod bolts
OBD2 oil pump
Gsr water pump
ARP head studs
Moroso oil pan
SpeedFactory sandwich plate
SF ls/Vtec kit
GoldenEagle dowel pins
Head:
94 spec GSR head
Bone stock except gasket matched ports
Ported GSR manifold
Egay header
Type R throttle body
Fueling:
Walbro 255
Precision 440 injectors
Stock rail
Stock fpr
Stock lines
Chipped LS Ecu added vtec
Best Guess Basemap.. Untuned
Exterior:
Stock struts
Skunk2 coil over sleeves
2011 Honda Fit 16" wheels
Bald *** street tires
Stock front/rear disc brakes
eBay mugen lip
Spoon cf duckbill
Interior:
Stock dash
Ej1 Ex model door panels
All power option converted
Front/rear gsr leather
Still don't know power wise what I'm making but.
Current best run on street tires:
R/t: .004
60ft: 2.5
330: 6.7
1/8: 10.1 @ 72
1000: 13.0
1/4: 15.4 @ 92.8
I'm in progress of getting some radials to cut the 60ft down and got some 15" steelies to run.
Pictures of the car will be up soon.
Bottom end:
B18a block
Clevite bearings
Stock Rods
ARP rod bolts
OBD2 oil pump
Gsr water pump
ARP head studs
Moroso oil pan
SF ls/Vtec kit
Head:
94 spec GSR head
Ported GSR manifold
Egay header
Fueling:
Walbro 255
Stock rail
Stock fpr
Stock lines
Exterior:
Stock struts
eBay mugen lip
Spoon cf duckbill
Interior:
Stock dash
R/t: .004
60ft: 2.5
330: 6.7
1/8: 10.1 @ 72
1000: 13.0
1/4: 15.4 @ 92.8
I already know the head is being restricted. The stock manifold doesn't supply nearly enough air and since I'm sticking with an all motor set up I really need cams.
And like I said the tires wouldn't grip in the 60ft as you can tell by the numbers.
But you already know this.
hey at least hes out there practicing.
but your times should be alot better. maybe your tune is all f-d up and not so much that intake mani.. but with a eg and a stock ls and the rear gutted you should be able to hit 14.8-6 pretty easy on street tires
that build can easily run low 14's high 13's. until you upgrade the cams.
Will have to get more of it inside the car now.
But it was a field pickup car that sat for five years outside.
And the picture of the car is right before i pulled the old LS out.
Car developed a nice clutch slip so now it's time to upgrade from stock.
Just got the skunk2 manifold and 70mm TB in today. Pics will be up later tonight.
soo... after i got the intake and TB in got two pulls out of the car and broke the open diff.
Just picked up full 96 spec ITR transmission internals and LSD.
Also picked up a Stage2 CC clutch kit today to address the clutch slip issue.
Working on uploading pics, but phone is being stupid.
i did a tooth count on it today since its taken apart, original trans was definitely a GSR however i had a slipping clutch at the time.
New setup thats going in on monday after a flywheel resurface is what i stated three posts up from this.
Pic 1: is the new intake/throttle body
Pic 2: Broken open diff before i took it out.
Pic 3: old gears left, new gears right with Synchrotech Synchros
Pic 4: the old n new differentials.
hmmm swear i've seen this car's orange twin rolling around here in portland.
clean lookin car tho man, couple things i'd have done different but over all good build
I'm going to be getting a new header soon. Stupid *** eBay one barely fits below oil pan and jus looks shitty and I know it doesn't do much, if anything, to help.
PLM one is in my sights.
The cams are gonna be in place after I build the head.
*just got the diff bearings swapped over today and got the internals in the tranny ready to go. More update tomorrow!
Cars been running now with stage2 CCI clutch kit from SpeedFactory Racing.
Gotta say I cant wait for it to be broke in and see how much of a difference the intake manifold/TB/LSD combo is making.
Next on the list is Header and then Paint this fall.
Heading to TnT tonight @ PacificRaceways to get a second timeslip. Will update after i get back home. Already been digging around dyno charts/forums/chatting with local tuner about header design and thoughts. So far on my small bore im thinking either PLM toda rep or Skunk2 Alpha because they are real close in flow. any insight?
bad news, SCHA was all messing up. couldnt get into 2nd for the life of me then an awesome attempt on the second pass and WHAM! no more go power. taking the tranny out/apart tomorrow after work to go right back into figuring out what happened.
Since tranny was fixed:
-got avid 70a mounts
-new basemap which seems to be running a lot better. spent some time with the guys doing it.
But now tracks are closed down for season around here will have to get more times up in the spring.
PAINT COMING SOON
PAINT COMING SOON
You put a lot of work/time into this car and I can respect that. I just feel that it's a very "jumpy" build. Not very well planned out. I had a 4dr GSR with only a short ram intake run a 15.1. That's a much heavier car. All the mix/match parts you have and "base" tunes are messing you up. I think this motor has great potential if you sit back and re-think your plans. A good tune will make all the difference.
Good luck with the build. The car looks much better now than when you got it.
