93 Del Sol Compressor wont engage
Old Jul 5, 2012 | 10:45 AM
JeffC's Avatar
Default 93 Del Sol Compressor wont engage
Has the double relays hanging on core support. Condensor fan and Radiator fan run fine. Traced to relay, can remove and jump across plug and compressor runs and system all runs fine. Bought new relay, same problem. Its a 4 prong relay, dont have schematic but seems awful strange will run compressor when jumped at connector. What am I missing? When I test plug, 2 terminals are hot with key on, 1 has ground. 1 seems dead.
Old Jul 5, 2012 | 11:25 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: 93 Del Sol Compressor wont engage
Are you low on freon?
Old Jul 5, 2012 | 11:58 AM
JeffC's Avatar
No. Sytem works normally when jump across connector. Put gauges on it to make sure and pressure is good. What I really need is a schematic of the relay connector, It appears Im missing a ground. My guess is ECU supplied.
pirrello
14
Aug 11, 2017 07:13 PM
K Brockschmidt
Aug 21, 2014 09:31 AM
jenishereto
May 15, 2013 03:35 PM
Michael Thomas
11
May 2, 2012 09:08 AM
delsolcharli
Jul 27, 2008 11:26 AM
