LC-1 wideband in s300
Hey fellas could really use some help.
I have a LC-1 with a db gauge. I am lost on how to hook up the LC-1 to the s300. I am wanting to keep my primary o2 hooked up as well as the wideband. So my question is what wire would I tap into for the wideband so s300 reads it? Please help.
Thanks
Thanks
Surely they have instructions? Have you checked the manufacturers website? Surely one of these Google search results can help you?
https://www.google.com/search?q=lc-1...ient=firefox-a
Maybe a call to Innovate for support? Surely you might have found this chart had you searched?
http://www.lukekailburn.com/lc1.html
I've searched and yes I found the website you did. But his is for removing the primary o2 and installing wideband. So I was trying to find out if I could tap into the o2 wire like Luke says to do or is there another wire to use so the s300 will pick up wideband.
You will want to go into your S300 software and select Parameters. Then select closed loop. At the bottom of the closed loop page you can change your settings under the wideband option. Once here you can select what pin is the input and the input voltage range and conversion tables.
Hope that helps. Be aware that an input on these other pins may require modification of your ecu with resistors or having pins desoldered.
BigMoose
Jan 29, 2003 02:31 PM
