94 Integra RS, H22a, Hasport, Koni, ASR
1994 Integra RS
Granada Black Pearl
240k Miles
Clean Texas Title
Motor:
JDM H22a from HMO, ~90k
Megan SS Header
RSR Exhaust
Skunk2 Intake Manifold
CF Whale ***** Intake
Walbro 255LPH Fuel Pump
Hasport Mounts
Spec Stage 3 Clutch
New Aluminum Radiator (500 miles ago)
New Timing Belt (Honda, 500 miles ago)
New Water Pump (Honda, 500 miles ago)
New Thermostat (Honda, 500 miles ago)
New NGK Plugs (500 miles ago)
Suspension:
Koni Yellows
Extended Tophats
Ground Control Coilovers (Has 2 collars on each coil to make adjusting easier)
Skunk2 Springs, 8k, 6k
ITR 22mm Rear Swaybar
ASR Subframe Brace
Hard Race Rear Trailing Arm Bushings
SS Brake Lines
Stock LS Mesh wheels
Interior:
Stock everything, including seats and steering wheel.
No Bride Seat
Missing Head Unit (Comes with an amp that is wired to all the speakers. Just need an mp3 player or phone and it's good to go).
This car had AC until some roadkill pulled my lower line towards the header and melted a hole in it lol. So a new line and recharge and it'll be up and running again. Car also had power steering until the pump went bad, thought it would be nice without PS, but it's not. Currently, I have the lines looped and an external reservoir to keep the rack lubed, until I find a new pump.
Paint's not in that great of shape. Repainted the roof with chalk board paint, so you can draw on it and what not.
Pics:
$3999
Again, OEM Seats, OEM steering wheel with airbag, and LS Mesh wheels.
Add $800 for the Enkei PF01 15x8 +35 with Falken Azenis (rather keep these since they're pretty much new)
Granada Black Pearl
240k Miles
Clean Texas Title
Motor:
Megan SS Header
RSR Exhaust
Hasport Mounts
Spec Stage 3 Clutch
Suspension:
Koni Yellows
Extended Tophats
ASR Subframe Brace
SS Brake Lines
Interior:
No Bride Seat
Pics:
$3999
