build thread
Old Jul 5, 2012 | 09:10 AM
2damnlow's Avatar
Default build thread
new build thread peoples, ok so this will take some pages to get us caught up to present so for all of you that are familiar with the work done to this car up until now just bare with me
I found the car for sale here on HT back in Dec and drove down to Tennessee to get it in Feb, here it is before I owned it
It did not come with a turbo or that motor in it^
came with a stock D16z6 and a **** ton of problems (don't know if the dude who sold it to me was trying to cut corners to get it together so he could sell it or if he was just retarded) any how I paid $3100 for it
here is how it looked when I bought it
problems...
well first off it came wire tucked, the dude who did the tuck was nice enough to use no oem connectors or solder just wires twisted together and taped and also about half the zip ties needed to actually keep all the wiring up and away from things like feet and/or the front wheels also no rubber grommets were used just holes cut and drilled in the firewall, wires run through them and spray foam sprayed all around them, some wiring problems caused by all of this were but were not limited to
. ignition would not kill engine if parking brake was up
. if you turned the lights on with the ignition off the radio would come on as well
. if you turned the key to accessory the lights would come on
. if the lights were on the car would not start
and so on and so forth in that manner
also the car came with no exhaust just about 2.5' of straight pipe
the wipers didn't work
the dash, center console, seats, basically all the interior came with only about half the bolts in it and all rattled like hell
there was a crappy traction bar WELDED to the car with about two spools of wire for some damn reason
most of the aluminum lug nuts were badly stripped and barely hanging on
the intake tube that came on the car was a soup can with the bottom cut out
and well that's all I can think of right now
Old Jul 5, 2012 | 09:17 AM
2damnlow's Avatar
Default Re: build thread
here are some parts that I had waiting on it when I got it home
Old Jul 5, 2012 | 09:50 AM
2damnlow's Avatar
first off I fixed all the wiring, then built a intake, and replaced the over flow, cleaned up the bay, shaved and painted the valve cover, got front bumper lights, put in my shifter and ****, installed steering wheel and put some ebay exhaust on it
here is the bay with a temporary intake
new intake, I made it out of an old tube I had laying around, some autozone parts, and a machete
overflow
and other pictures around that time period
Old Jul 5, 2012 | 10:09 AM
2damnlow's Avatar
of course I used a grinder to remove the paint from the fenders and deck lid, and mounted my mirrors
then my side markers
^^what you are seeing on the car is salt, I sprayed salt water on it to rust the metal
Old Jul 5, 2012 | 10:39 AM
2damnlow's Avatar
test fit wheels
took the front end off and painted it
Old Jul 5, 2012 | 11:12 AM
2damnlow's Avatar
painted and wheels on
new radiator
stickers
and some randoms from around that time
Old Jul 5, 2012 | 12:18 PM
Aftermath_Hatch's Avatar
Looks like your doing a good job,love the engine bay pretty clean.I'm not to crazy about the fenders and trunk,but just my opinion.Keep up the good work.
Old Jul 5, 2012 | 12:41 PM
TearSDMF89dx's Avatar
i have the same issue with the fenders/trunk/mirrors deal but its your car your style ....other than that good work
Old Jul 5, 2012 | 02:59 PM
2damnlow's Avatar
front bumper
first I took it down to the core support and painted it red
I cut everything out of the cover
also I had to cut down the foam
and the bumper support
this is how much I cut out of it
here it is all back together, also I had to extend and raise the wires behind it so you couldn't see them through the bumper
Old Jul 5, 2012 | 03:03 PM
2damnlow's Avatar
thanks guys, I should have started this thread months ago when I got the car now I have to play catch up
Old Jul 5, 2012 | 03:20 PM
2damnlow's Avatar
then I lowered it some
did my first of many poor mans alignments on it (this time was before I lowered it the first time) you will have to excuse< I'm tring my best to get everything in chronological order
Old Jul 5, 2012 | 03:22 PM
2damnlow's Avatar
then got my jetta lip
Old Jul 5, 2012 | 03:39 PM
2damnlow's Avatar
rear fogs
I also installed my hood pins around this time but can't find my pictures of doing so, and its a little lower in the last few pictures^^^
Old Jul 5, 2012 | 03:58 PM
2damnlow's Avatar
side skirts ( off an ek sedan)
the amount of plastic I had to cut off of them to get them to fit
then of course I had these gross holes in the fronts of them
so I made these nifty caps out of the front ends that I cut off
Old Jul 5, 2012 | 04:01 PM
4drEF's Avatar
Keyboard Humorist
You paid $3100 for that?
It looked rough in the 'before' pics, but I think I liked it before you personalized it =/
I can not comprehend the rust... but it's your style so I guess you did a good job removing the paint from the upper half of the fender. Black bumpers, white body, and rust really not flowing well in my eyes.
Fender mirrors were in Japan until 1981?
Please stick to mirrors that were time-period correct for your car.... or at least paint them.
Chrome is not working at all for that car.
The black triangles where the mirrors should be is making the window look funky.
Black like these is you MUST have the fender mirrors.
Old Jul 5, 2012 | 04:08 PM
2damnlow's Avatar
coffee can column, I know a lot of you have steering hub adapters and a lot of you probably hate that they don't cover the whole hub like so
well here is my solution
Old Jul 6, 2012 | 10:37 AM
2damnlow's Avatar
fun I get to go through to get it up on my lift
Old Jul 6, 2012 | 10:54 AM
2damnlow's Avatar
I rebuilt the front brakes off my burnt sedan and put them on
here are the brakes that came off of it
randoms
Old Jul 6, 2012 | 11:11 AM
2damnlow's Avatar
I ****ed up my exhaust on a unsavory railroad track
so i just did this (yes it is loud as hell)
^^^this is what it looks like now except i have a more proper hanger on it
Old Jul 6, 2012 | 11:16 AM
2damnlow's Avatar
got tired of a bounce car and extended my top hats
stuck wheels vvvv
Old Jul 6, 2012 | 11:24 AM
2damnlow's Avatar
Old Jul 6, 2012 | 11:54 AM
2damnlow's Avatar
here is a picture of my oil pan that I took about three days before I drug through it
here is a new pan and how I solved the problem
Old Jul 6, 2012 | 12:09 PM
2damnlow's Avatar
most recent I fixed my deck lid because it wouldn't close right
like this
well that was because of this (and the lid itself needing a tweek)
so I gave it some of this (and beat the lid into submission with a rubber mallet)
now it closes perfect, also I tinted my tails red
Old Jul 6, 2012 | 12:14 PM
2damnlow's Avatar
well that brings us up to date, now I can actually post updates as they happen
Old Jul 6, 2012 | 12:45 PM
2damnlow's Avatar
next thing will be bagging it, all i still need to do that is
eg forks and tophats
50' of 1/2 air line
a few fittings
and sheet metal
here are the parts I already have
the drop in unit I built
switches
compressor switch
wiring to the trunk
airlift life styles air struts (for an eg)
two viar 450 compressors and gauges (this is the only picture I can find with my gauges in it)
wiring for gauge lights
and I have a two gauge a pillar pod but I don't have a picture of it on this computer
here is my set up sitting in the trunk
and my air and wire diagrams
