AEM CAM GEAR INSTALL D16Y8
Old Jul 5, 2012 | 06:53 AM
redred1188's Avatar
Default AEM CAM GEAR INSTALL D16Y8
Bought an AEM Camgear for my d16y8. im planning to install it myself.
Anyone got a video or write-up on how to install it? Pictures would be great help.
1. Set motor to TDC. Does this mean turning the crankshaft pulley bolt so that the white marker (right most marker) lines up with the plastic "V" on the lower cover?
2. Loosen tensioner. When i loosen this, the timing belt will loosen right? do I have to remove the timing belt when installing the AEM cam gear or ill just slide it up? do i have to mark the timing belt? i mean is the timing belt supposed to be on a particular mark? or its just a belt, thats it, no markings?
3. Remove stock camgear, install AEM cam gear. how do i do this, should i look for something like marks or anything? this is why i need video and pics.
4. after installing tighten tensioner and then turn crankpulley bolt so that the cam gear runs 3 teeth? how would i know that its installed properly and the belt is in the right tension?
Im hoping to know what to look for, the important things i should look for, coz im worried i might mess up my engine. but i want to learn.
Old Jul 5, 2012 | 07:16 AM
kyden's Avatar
Default Re: AEM CAM GEAR INSTALL D16Y8
1. yes.
2. yes you will have to remove the timing belt. (at least off the gear anyway) grab a manual and follow the directions for replacing the belt.
3. it should be self explanatory when you see it.
4. see #2.
any reason you are putting the gear on? it does nothing for performance unless you are trying to degree the cam.
Old Jul 5, 2012 | 10:09 AM
MonkeyMagic's Avatar
wonder if this would be in a haynes manual? might be worth looking into
Old Jul 6, 2012 | 08:59 AM
HCivExoo's Avatar
Buy a Haynes or similar manual from a local autozone store or something and learn. This is also a covered subject if you searched the archives
Old Jul 7, 2012 | 08:03 PM
mouab18c1's Avatar
The Chiltons book is not bad either. I've had mine for 6 years now.
92LXcb7
Jan 6, 2012 03:31 AM
sins
Nov 5, 2009 12:45 PM
Swansen
15
Apr 1, 2009 02:39 PM
jtchinoy
May 11, 2006 08:25 PM
Slammd Sol
18
Aug 15, 2005 05:48 PM
