problems with my Skunk2 Intake manifold...***help***
Old Oct 14, 2002 | 10:01 PM
JDMkings's Avatar
Default problems with my Skunk2 Intake manifold...***help***
i have a 01 GSR and i installed a Skunk2 manifold and the car idles very poorly. Also when i step on the gas the car kind of dies out. any suggestions? i know there are some sensors that u don't use from the stock gsr manifold...can anyone help me...thanks in advance
_______
Old Oct 14, 2002 | 11:25 PM
tonyxcom's Avatar
Default Re: problems with my Skunk2 Intake manifold...***help*** (JDMkings)
dont you need an ECU reporgram so that the ECU doesnt try to operate the secondaries or something?
Not sure, just a guess.
Old Oct 15, 2002 | 04:38 AM
FifthGearOnline's Avatar
Default Re: problems with my Skunk2 Intake manifold...***help*** (tonyxcom)
couldnt hurt to pull the ECU fuse for about 3-5 mins
Old Oct 30, 2002 | 05:46 PM
not133t's Avatar
i recently installed the same into my friends '99 GSR and had the same problems. Check all the sensors according the the diagram on the bottom of your hood. That should take away the bogging.
Old Oct 30, 2002 | 08:52 PM
CivicEx95's Avatar
make sure the IACV on the back of the manifold is hooked up correctly. If it's not hooked up at all, you'll get a CEL and the idle will be like 200 rpm
krnboynemesis
Jul 4, 2005 11:13 AM
JDMkings
Oct 15, 2002 04:32 AM
Kalokohan
Mar 18, 2002 01:03 PM
B19CivicHB
Jan 22, 2002 02:13 PM
