92-95 L3 Trans into 90 CRX Si
Old Jul 3, 2012 | 07:20 PM
lewzor's Avatar
Icon2 92-95 L3 Trans into 90 CRX Si
Hello. So I got this L3 cable trans that is hooked up to a 92-95 EX motor that is shot. Will this trans mate with the D16a6 that is in my CRX Si? What do I look for? I have read about the splines and stuff. Looked up the alignment tools used on both types of cars...I was just wondering if anyones knows right off if I can someday use the EX trans to swap with my Si trans or just sell it on craigslist.com...thanks.
Old Jul 3, 2012 | 07:40 PM
LSx Envy's Avatar
Default Re: 92-95 L3 Trans into 90 CRX Si
If its a real L3 cable trans it should be plug and play.. Hell it probably originally came out of a CRX..
Old Jul 4, 2012 | 04:41 AM
probowler2286's Avatar
cable trans to an obd0 motor, shouldn't be a problem, not like you're re-using the clutch (I'd hope)
Old Jul 6, 2012 | 04:28 PM
lewzor's Avatar
Thanks a lot! I am going to switch out the transmissions (with a new clutch and resurfaced pressure plate and stuff) and fix the bearings that are making noise in the origional.
Old Jul 7, 2012 | 09:10 AM
kaminsknator's Avatar
just count the splines before you order a clutch could be an oddball 20 spline
innes887
Apr 14, 2007 03:03 PM
littledevil46
Jul 18, 2006 09:26 AM
RCautoworks
Jul 16, 2006 10:05 PM
psilberschatz
Feb 7, 2004 07:28 PM
