1999 accord
Old Jul 3, 2012 | 06:47 PM
kidstoy9's Avatar
Default 1999 accord
hi all i have a 99 accord and just put a used transmission in and now the car does not move at all is there a special way to fill the trans or fill torque convertor?
Old Jul 3, 2012 | 07:40 PM
tim73's Avatar
Default Re: 1999 accord
Did you check the fluid before you started the engine? Normally they're filled through the dipstick spout. You did remember to bolt torque converter to flex plate right?
Old Jul 4, 2012 | 05:54 AM
kidstoy9's Avatar
yes the torque convertor is bolted to the flywheel i put 3 qts in and it acts like the torque convertor is not filling up the car goes in drive but does not move no lights are flashing and the check engine light is not on
Old Jul 4, 2012 | 06:48 AM
tim73's Avatar
Did you double check all electrical connections are fully connected? And that theyre corrected to the right connector? I would double double check, the install, making sure nothign was missed or pinched, and the shift cable is properly installed. I was going to say, the torque converter wasnt seated properly, but i believe in that situation, the fluid leaks out.
But if all that checks out, it soulds almost like the pump isnt making any pressure. I would take it in, if the install looks right. Youre certain the transmission worked before you put it in?
Old Jul 4, 2012 | 04:43 PM
kidstoy9's Avatar
thanks for the help the pump is not working properly just pull it out again and get another trans
BDB_LV
Apr 5, 2013 05:43 AM
miguel11691
Mar 6, 2012 10:58 PM
okiekid93
Jan 7, 2012 10:08 AM
ForceXVII
Aug 22, 2003 11:49 PM
hybrid22l
Jul 12, 2001 01:31 AM
