relay switch 87 honda crx si
Which one? The Main Relay?
1: Lay relay on ground in front of you.
2: Bend at knees and push off ground by extending legs as hard as possible with a slight forward motion.
3: Land on other side of relay...
Seriously though, if you mean the Main relay then here:
Disregard the blue writing, that was for someone else. Just used the same pic. Btw, go get you a new relay. Jumping things may be ok for getting home when stranded or troubleshooting, but there is a relay there for a reason. Kinda like fuses... I hate to see someone bypass something and burn their $@it up...
GS8HFL21
Nov 9, 2005 06:56 AM
