99 Honda accord lx automatic f23a1
Old Jul 2, 2012 | 08:55 PM
Hondaciv866's Avatar
Default 99 Honda accord lx automatic f23a1
my friend has this car. He has the stock f series transmission. And quick research shoes that these automatic trannys are notorious for leaking and failing. My friend is having both of these problems with his accord. I m not to farmiliar with the accord, but i have done plenty work on a civic. Anyways i dont see the point on him picking up another f series trans to swap in that will just end up failing again anyways. I did some research, and havent found much. But one solution i did come across was that people were taking trannies from the preludes and dropping them into the accord.
So my question is will an h series automatic tranny drop straight into his accord without a hitch? and what i mean is will the ecu, sensors, mounts, starter, etc all line up perfectly without a hitch/?? or is it not that simple.
Old Jul 3, 2012 | 04:20 PM
hondamark35's Avatar
Default Re: 99 Honda accord lx automatic f23a1
are you sure the research you are doing (and finding H-series swaps common) is the auto and not the manual trans?
for that model year the V6 trans was the trouble prone version. the 4cyl trans wasn't great, but it didn't have problems like the V6.
his transmission is leaking..? fix the leak. it's failing? how exactly is it failing? hard shifts, won't shift, no lock-up... what sorts of symptoms are there?
in general, without inspecting the car first hand, these models are most often worth repairing.
Old Jul 3, 2012 | 10:15 PM
tranny slipping
Old Jul 5, 2012 | 08:17 AM
bump
Old Jul 5, 2012 | 03:31 PM
MAD_MIKE's Avatar
MM Gruppe B
http://www.sonnax.com/system/pdfs/35...pdf?1320330979
This is a good read on problems with the 98-02 4spds.
It applies to both V6 and I4 models.
Old Jul 5, 2012 | 07:27 PM
^thanks for the info.. i was more curious to know if the f and h series automatic trannies are straight swapable (no diff sensors or harness mods needed)
Nov 6, 2015 09:04 PM
acidburn2k2
Sep 22, 2015 10:39 AM
KreLude
Nov 3, 2009 10:12 AM
joe8mofo
Nov 5, 2008 08:18 PM
butand50
Nov 3, 2006 07:49 AM
