h22a ecu tuning versus b18c gsr
I have a p13 chipped ecu. The only thing that was done is rev, vtec limits, cel light. No other changes. I am wanting to find a map that makes.her scream. It is a type s h22a stock dome piston high compresion bottom end , and top is milled 40 thousands, intake had butterflies removed and header. Nothing big done. I am getting 181 to th wheels. Can this motor be tuned to near 200 whp . What do I need., and o was told to use a b18 gsr computer and map they said it would run better ?????? Please help
Read http://www.phearable.net/tech/efibeginnerguide.html
Because you have the butterflys removed you can tune the car on crome, ectune, neptune, hondata using a p28 spec ecu.
