FS: COMPLETE B18C1 GSR SHORTBLOCK WITH GOODIES CHEAP
Text: 626-235-0008
WILLING TO TRADE FOR KSWAP PARTS INTO 94-01 INTEGRA
NEED THIS GONE, BEEN SITTING FOR AWHILE. ONLY 1200MILES AFTER THEBUILT. BUT IT WAS SMOKING SO NEED IT CHECKED OUT, MIGHT NOT BE THE BLOCK, MIGHT BE MY HEAD. BOTH HAS NOT BEEN CHECKED OUT. WHAT YOU SEE IS WHAT YOU GET, I HIT 218HP @ Import Auto Pros WITH THIS BLOCK.
NOTE: I WAS USING A 81MM HEAD GASKET AND THE BORE BLOCK WAS 81.5MM. SO ITS POSSIBLE OR IT IS THE HEAD GASKET PROBLEM. I NO LONGER NEED THIS AS I AM GOING K-SERIES.
Block =
GSR B18C1 BLOCK
Bore Block DECK AND HONED 81.5MM DONE BY RS MACHINES $300
RS MACHINE NEW PR3 B16 HIGH COMPRESSION PISTONS $220
Stock Rods and Crankshaft
ARP NEW Rod Bolts $90
ARP NEW Head Studs $110
Block Guard $80
OEM Type R NEW Oil Pump $120
ACL NEW Race Bearings KIT $120
Moroso NEW Oil Pan $180
$500 FIRM FIRM NO BS NO LOWBALLERS I AM FIRM
Text: 626-235-0008
Block =
GSR B18C1 BLOCK
Block Guard $80
i bought the car with the block guard on and don't know the brand. Not sure if it is welded in, RS Machine said ok to leave it on when they did all the machine work. I am not sure if i still have that paperwork from RS, i will look for it and let you know asap thanks
as i stated, i am not sure what is wrong with it. i was using a 81mm cometic head gasket and my block was blocked to 81.5mm. I cannot find the paperwork done by rs machine, only found receipt for itr oil pump and acl race bearings kit.
From: im nothing from no where im no one at all, ca
so what kind of smoke we talking about here? like smoke bellowing out of the back? white smoke? black smoke? oil and water mixing? pm me if youd like, looking for a block to throw into my DD. thanks
