FT/FS 1998 Acura Integra JDM Front
Looking to trade for something else or sell outright at $6500
Motor Rebuilt at 195495 Miles
1998 Integra Fresh Indiana
LS body and Clean Title
Tuned on eCtune Dave Blundar
205,000 on Body
P/w + P/L
Brad Penn 10w30 oil and and filter changed every 3k
Chipped p28 obd2-obd1 harness
Engine:
JDM b16 head
Port and Polished
Buddy Club cam gears
ITR Cams + internals
Hytech Replica Header + Test Pipe
T1R full exhaust
Ebay intake + k&N air filter
Skunk2 Pro S intake Manfiold
Hondata Intake Manifold Gasket
AEM fuel rail + AEM FPR
Fuel Pressure Gauge
NEW NGK blue Wires
NGK spark plugs
Skunk2 short shifter
Walboro 255 Fuel Pump
GSR Tranny
Brand New OEM pilot + Throwout bearing
Both Tranny Seals
Exedy Clutch
Fidanza flywheel
GM Syncromesh filled 11/11/09
Block:
GSR 81mm Bore
New JE 12:1 Pistons
Eagle H beam rods +ARP rod bolts
ARP headstuds
Crank Polished with .10 oversided rod bearings
New ACL Race rod/main/Thrust
OEM Headgasket
New ITR oil pump
All new OEM bottom end gasket set
Suspension/Breaks:
Tokiko illumines 5 way adjustable
Ground Control Coilovers
ITR front strut bar replica
DC rear strut bar
Skunk 2 Front camber kit w/ Blox ball joints
Blox Rear Camber kit
Slotted rotors front + new ceramic break pads
Wheels:
16’Maxim Lemanns
205/45/16 Nitto Neogens
Muteki lug nuts
Interior:
Clean 9/10
ITR shift boot
Spoon TI shift ****
Alpine Headunit
GSR leather door panels w/ tweeters
GSR leather front and back seats (front and rip in middle cushin)
Body:
7/10 needs some work done but no rust
JDM itr front end
Black housing headlights
Shaved side moldings (welded) right way
8k HIDS
Password JDM side markers
Bad:
Needs paint and work on rear bumper, No A/C, ABS light on, Crack in Windshield (got it with the car), High RPM grind, p/s leak but i have the unit to fix, Common acura actuator problem, needs alignment because just lowered it in the summer.
Overall this has been my DD for over 4 years and wouldn't hesitate to drive it anywhere. I would love to finish it but i need to finish up school and ready for a change.
I'm willing to throw cash on top on my end too for another car.
I have plenty of reciepts and pics from the build for serious buyers. Thanks for looking and please bump
205,000 on Body
P/w + P/L
Engine:
JDM b16 head
Port and Polished
T1R full exhaust
Fuel Pressure Gauge
NEW NGK blue Wires
NGK spark plugs
GSR Tranny
Both Tranny Seals
Exedy Clutch
Fidanza flywheel
Block:
GSR 81mm Bore
New JE 12:1 Pistons
ARP headstuds
OEM Headgasket
New ITR oil pump
Suspension/Breaks:
DC rear strut bar
Wheels:
16’Maxim Lemanns
Muteki lug nuts
Interior:
Clean 9/10
ITR shift boot
Spoon TI shift ****
Alpine Headunit
Body:
JDM itr front end
8k HIDS
Bad:
jonesEK
Nov 10, 2015 07:45 PM
bew
Aug 13, 2003 07:30 PM
rubens
Aug 17, 2002 02:35 PM
