What size exhaust piping for my car....
Old Oct 14, 2002 | 08:56 PM
cruzersi99's Avatar
Default What size exhaust piping for my car....
I have a mildly modified b16 (1999 Si), with CTR/ITR valvetrain and cams, dynoing 167 WHP. I am currently running a JDM 4-1 header and 5zigen fireball exhaust. I was considering changing my exhaust. is 2.5 inch piping too big for my application?
Old Oct 14, 2002 | 08:57 PM
vtec.dc2's Avatar
Default Re: What size exhaust piping for my car.... (cruzersi00)
167whp - in my opinion - is enough for 5zigen to handle
Old Oct 14, 2002 | 08:58 PM
Ferrell's Avatar
Default Re: What size exhaust piping for my car.... (vtec.dc2)
2.5inch would be just fine.
Old Oct 14, 2002 | 10:13 PM
IGGY's Avatar
Default Re: What size exhaust piping for my car.... (Ferrell)
Old Oct 15, 2002 | 12:36 AM
Maximus's Avatar
Default Re: What size exhaust piping for my car.... (IGGY)
Since you already have an exhaust you can save some money and buy another mod. Unless you plan to make a lot more whp in the future.
Old Oct 15, 2002 | 01:02 AM
d0nkeyxPunch's Avatar
Banned
Default Re: What size exhaust piping for my car.... (Maximus)
i dont think 2.5 in piping for a mild setup like that is necessary.....i would just stick with 2.25 in. piping
Old Oct 15, 2002 | 01:07 AM
B2FiNiTY's Avatar
Your exhaust is fine.
Old Oct 15, 2002 | 02:29 AM
00MRSi's Avatar
Default Re: What size exhaust piping for my car.... (ExOdy)
You make 167 whp with CTR cams? Can you list your mods. I agree with Exody, your 5ZIGEN exhaust should be fine for your application..
Old Oct 15, 2002 | 07:47 AM
cruzersi99's Avatar
My setup is as follows:
CTR Cams
ITR Intake Manifold
ITR Valves and valvesprings
11:1 Compression
3 angle valve job
JDM 4-1 with modified stock cat
5zigen Fireball
Comptech Icebox intake
I am probably closer to 170 now without power steering. I also have a spoon TB on the way. I was thinking about getting a new cat to match my header, but I am hesitant to do even that if it is all going into 2.25 inch piping anyways.
Thanks for the input. This is why I hang out in this forum instead of the EG forum.
Cruzer
Old Oct 15, 2002 | 11:08 AM
00MRSi's Avatar
Nice #s. How did you get the 11:1 compression? Milled head, thinner headgasket? You are still using stock (b16) pistons? Thanks..
Old Oct 15, 2002 | 11:10 AM
(__________)'s Avatar
Default Re: What size exhaust piping for my car.... (00MRSi)
2.5 would be fine
Old Oct 15, 2002 | 11:17 AM
cruzersi99's Avatar
I raised compression by milling the head.
It seems like 50 % feel i need to go to 2.5 , and the other feel 2.25 is fine....hahahaha
Old Oct 15, 2002 | 11:20 AM
Big Phat R's Avatar
60 mm
Old Oct 15, 2002 | 11:23 AM
Raymund's Avatar
New User
Default Re: What size exhaust piping for my car.... (steves98itr247)
Would a 2.5" loose some low-end compared to a 2.25" with his particular application?
Old Oct 15, 2002 | 11:29 AM
00MRSi's Avatar
Default Re: What size exhaust piping for my car.... (Raymund)
60mm piping is more than enough for your mods. I believe the 5ZIGEN fireball piping is 60mm. Most of the aftermarket exhausts like GReddy, Tanabe, APEXi, Skunk2/RSR, etc. are 60mm, aprx. 2.38" diameter piping. I think Thermal R&D uses 2.25" piping. You can't go wrong with either, but 60mm is more than enough..
How much was the head milled?
Old Oct 15, 2002 | 11:48 AM
cruzersi99's Avatar
I believe the head was milled .30, just enough to bump up to 11:1 where it would be safe to run 91 or 92 octane gas, and just enough so that i could run bigger cams if i wanted to.
Thanks for all the info...
Cruzer
Old Oct 15, 2002 | 12:14 PM
Mr Hammond's Avatar
a/k/a Jomo
modifed stock cat? man ditch that thing for a carsound 94006. 170whp+ is yours.
Old Oct 15, 2002 | 12:56 PM
Hooch'n's Avatar
Default Re: What size exhaust piping for my car.... (Mr Milano)
2.5 would be nice.
Old Oct 15, 2002 | 01:02 PM
4-1-1's Avatar
Default Re: What size exhaust piping for my car.... (Hooch at 8400-RPM)
Get a new cat
Unjockable
Apr 11, 2005 03:01 AM
{Powered by VIII}
Apr 4, 2005 09:51 PM
SamC
Jul 28, 2003 08:44 PM
cruzersi99
Oct 21, 2002 07:14 PM
Mr. Softee
Jan 22, 2002 03:43 PM
