D16a6 into 1996 Honda Civic DX
Old Jul 2, 2012 | 12:38 AM
Randolph's Avatar
Icon2 D16a6 into 1996 Honda Civic DX
Ok so now its running as follows:
D16A6 in a OBD2a EK hatch
D16Y8 distributor
P2P ECU (D16Y8)
red lines at 5600 because thats when vtec kicks in on this ecu
So which ecu should we be running? A P06 with a step down? What about the distributor? Would like to get it to run full to 7K rpm.
Brand new spark plugs and o2 sensor as well. Someone has to know something...
Old Jul 2, 2012 | 01:33 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: D16a6 into 1996 Honda Civic DX
What intake and exhaust manifold did you use? You can't use a two wire IACV with the P2E ECU. Have any check engine lights?
Old Jul 2, 2012 | 08:43 AM
Randolph's Avatar
d16z6 intake manifold with the d16a6 header it came with. and yes there is a cel...but the shell is a obd2a shell with a obd0 motor etc. Should we still plug it up with a obd2a scanner? And he isn't using a P2E ecu...I said P2P.
Old Jul 2, 2012 | 11:47 AM
Randolph's Avatar
Any ideas?
Old Jul 3, 2012 | 10:05 AM
Randolph's Avatar
any1?
Old Jul 3, 2012 | 05:09 PM
fonkernuckle's Avatar
Doesn't the 96 have a crank position sensor and crank gear with "teeth" that the crank position sensor picks signals up from (located at the front of the engine slightly behind and to the side of the crank pulley). earlier models have it in the dizz but the later have the sensor. Could this be what you are missing
Old Sep 6, 2012 | 02:59 PM
Randolph's Avatar
Could be? We haven't touched any of that.
D16Y8 distributor
P2P ECU (D16Y8)
Old Sep 6, 2012 | 03:49 PM
Yourmomsaid's Avatar
Bump
Old Sep 6, 2012 | 06:10 PM
Technical Hero
Running a p06 will eliminate half your OBD2 issues but you'll still need to change the IACV to 2 wire at the plug and ECU.
Old Apr 19, 2017 | 11:33 AM
calebmeat's Avatar
Hello, sorry but what engine mounts you use to bring the a6 block in the Ek ??? Can you give me a pic???
dmt0000
Oct 15, 2012 08:12 AM
mike93eh2
May 25, 2007 05:02 AM
cloven
Feb 8, 2006 11:47 AM
