Epic part out! Jo-tech turbo kit, sportline springs, pioneer navigation...much more
Old Jul 1, 2012 | 02:41 PM
snizzletoff's Avatar
Default Epic part out! Jo-tech turbo kit, sportline springs, pioneer navigation...much more
All these parts were pulled off of a 2006 civic si
Hello all! Its been great but i have decided to part out my si in hopes to move onto another project!
First is my jo-tech turbo kit, this kit go me 417whp/298tq on 12psi tuned by Vitviper
Dyno:
I am the second owner of this kit, the downpipe was modified by the previous owner. The old owner put a flex pipe on the downpipe and it was too long to bolt up to my q300 exhaust. I shortened the downpipe but do get the right angle it required we patch it on the bottom.
It doesn't look the greatest but the welds are very good and it doesn't leak or effect performance at all!
Other than this the kit has no flaws, and makes great power!
Also replaced all seals, gaskets, and bearings in this turbo when I installed it in December!
I do not want to ship the very large items, if a product says shipped beside it, that's the price shipped to your door, if it doesn't say shipped then add shipping. I am willing to drive and meet up with you for the turbo kit its very heavy and i don't want it to get damaged.
On to the goodies!
Jo-tech Turbo kit- Includes : PT 6262 turbo (journal bearing) , 3in downpipe, j-tech tubular manifold, all charge piping, intercooler (rated for 650hp) , Tial 50mm Blow off valve (Can include white and pink spring) , tial 44mm wastegate with 10psi spring and open dump, Greddy profspec II boost solinoid, apexi turbo timer - $3500
Oilpan- stock oil pan with a -10an bung welded on, Also has an oversided oil drain plug, i was changing the oil and accidentily overtightened it, this new plug dose not leak at all!- $150 or 100 if you get it with the turbokit!
Go-power 1000cc injectors w/ plug and play clips- 375 3k miles Max
Dw300lph fuel pump 5k miles max- $80+ your stock fuel pump
I don't need to sell this, but i would rather someone use it then it sit in a stock car, I need your stock pump though. When a deal is made i can send you a picture of the pump prior to payment if you desire!
Hondata 4 bar map sensor: (8k miles) - $80 Shipped
Ebaich sportline lowering springs: 2kmiles- $180
Buddy club rear camber arms: not sure exact mileage i had them on for 2k miles - $160 shipped : PENDING SALE
ingualls front camber bolts, new set sold, other set has 2kmiles - $20 shipped
Xlr8 guage pod- $65 Shipped
Avic f90bt headunit - $470 Shipped
This includes scosche dash kit, Pac steering wheel controls, back up camera, Harness for a civic si with premium audio, ebrake disabled. This allows you to use your stock civic amplifier and sub!! Its running the 3.0 update and the latest map update!
flash pro - $550 Shipped
q300 exhaust- $450 4kmiles
skunk2 76mm - $150 Midpipe is too short, previous owner cut the flange off and shorted it. Its fixable but will sell just the resonator and axle back if wanted.
boomba torque mounts - $175 2kmiles
Competition stage 4 clutch (2k miles max) - $250
Corsport short shifter - $35 Shipped
fipracing_com
May 3, 2005 12:12 PM
slrh22hatch
Nov 20, 2003 05:40 PM
