!!!!> Lets Make A Deal <!!!! Bunch of parts
Im trying to clean out the garages, everything is make a REASONABLE offer, I will ship smaller stuff at buyers expense.
Located in La Crosse Wisconsin right on the border of Minnesota.
Best way to contact is thru pm.
Obd0 intake manifold was told it was off an LS
Obd0 b series dizzy will need a new coil and a cap
obd0 wiring harness pretty sure its out of an integra some plugs are missing/cut best used for parts.
Hks ssqv flange think it came off a dsm but can be used in other applications im sure
Obd2 P2e ecu think this is a dx ecu, I have never used it.
Garrett T3 hot side flange .48 has some small cracks but will work just fine.
spectre air filter basically brand new
B series timing belt covers will sell individually or all together
B16 black box will need new o ring
Obd1 b series dizzy was told it has a new coil I have never used it
Ls cable trans should be in good condition but I have never used it
stock civic radiator with slim fan works great no leaks
Blox D16 FPR worked great last time I used it
GSR transmission cases will sell together or seperate comes with the diff If you would like
shift forks from the gsr trans
counter and main shaft from the gsr trans, a couple gears/slider sleeves are worn might be good but I would replace them If i were to rebuild it, I would also replace the syncros but they might be ok for a while im not an expert.
Windage tray from ls block
pickup from ls block
rear main from ls block
came off gsr trans not sure if it works ive never used it
crank pulley off ls block
Ls counter shaft (SHAFT IS JUNK) some of the gears look to be ok though
Mainshaft forgot to check if its a ls or gsr I can check if someone is interested shaft itself is in good condition.
counter shaft, didnt see anything wrong with it
assortment of shift forks I think 1 set is from an ls and the other from a gsr not sure if they are different?? ill sell them all together.
2 oem diffs guessing from the one thats in the gsr trans, the one on the left is a gsr and the one on the right is an ls I think, both look to be in good condition.
assortment of gears and whatnot, im thinking some are ls and some are gsr some may be useable some are worn I will sell them all in a box together.
Intercooler, works great
b series half shaft
Garrett t3 center section oil/water, will need new bearings it is missing 1 of the bearings(think i put it in a different turbo) was used on a friends car before i took it apart so it is useable just needs a little work.
Ls Block has been hot tanked,deglazed,and the crank has been polished. stock bore. I have the stock rods and pistons too.
Make me offers, Not really looking for trades just cash. I also take paypal. Thanks.
b series half shaft
dtgodmage
38
Jun 8, 2011 06:54 PM
GeeGee
Apr 19, 2007 07:00 PM
B16CRXT
Dec 6, 2004 11:08 AM
