Speedometer, temp, fuel, and RPM needle not illuminated
Old Jun 30, 2012 | 09:29 PM
djkurious's Avatar
Default Speedometer, temp, fuel, and RPM needle not illuminated
I have a 95 EX and starting tonight, the speedometer, temp, fuel, and RPM needle not illuminated. I have the OEM gauges and it's never been changed or modified. Any suggestions?
Couldn't find a fuse. Picture provided is a close-up picture.
Old Jul 1, 2012 | 03:47 AM
GhostAccord's Avatar
Default Re: Speedometer, temp, fuel, and RPM needle not illuminated
Under hood fuse box
Fuse No.32 = dash lights, tail lights, parking lights and license plate lights.
Under dash fuse box
Fuse No.1 = Gauge Assembly, Backup lights, Clock, Vehicle speed sensor and shift lock solenoid (A/T)
If it is only your pointers that are out I would suspect a burnt out bulb or worn electrical circuit on the gauge itself.
Old Jul 1, 2012 | 01:24 PM
Jmb106jr's Avatar
Had this happen on my 95 lx there is a light bar mounted on top of the cluster and the bulbs burned out. you will have to pull the cluster out and replace the bulbs. I picked some up while at the bone yard, now i keep some in my tool box just in case.
Old Jul 1, 2012 | 06:50 PM
djkurious's Avatar
Thanks for the advice. Will be going to the bone yard tomorrow!
Mark
Sep 1, 2011 12:45 PM
legendisdope
Jan 29, 2007 07:17 PM
novvti
Mar 5, 2006 09:59 PM
98IntegraLSNonVtec
Feb 24, 2006 10:07 PM
SFC
Jun 30, 2004 09:23 PM
