Need info on tranny swap for ed6
Old Jun 29, 2012 | 10:06 PM
AH419's Avatar
Default Need info on tranny swap for ed6
I have a daily driver/project ed6(std) and am looking into swapping the tranny from a 4 speed to an si 5 speed, because i have a newly rebuilt d15 with some good power but not enuff wheel power. i am converting to mpfi soon and would an si tranny do the trick to release the horses? And if so what is invloved?
Old Jun 30, 2012 | 12:24 AM
93delsold16z6's Avatar
Default Re: Need info on tranny swap for ed6
Any D series tranny will bolt up to any D series block. Only thing is make sure if its cable to get cable, and if hydraulic to get hydraulic.
You would need to connect the appropriate shifter linkage and shifter base as well.
Maybe therei is more but thats all I know of and can think of at 4 AM
Old Jun 30, 2012 | 07:58 AM
tonylovesjdmEF9's Avatar
look your std so you got a crappy 4spd just get any of the ef 5spd trans and you will be fine no need to change axels or anything else just drop and install new one.....just to remind you the si trans is hard to come by but its worth the money and also since its shorter gearing you will be at 4000rpms at 80 3500rpms at 75ish.. i daily my ef with d15b vtec (jdm) with the si trans. its amazing feel of the sohc the si trans cuz it pulls and pulls but then again mpg drops a bit and its annoying going to the fwy at such high rpms
Old Jun 30, 2012 | 08:17 AM
I will trade my SI trans for a hf or s20
Old Jun 30, 2012 | 10:35 AM
KINGVEM^^ED6's Avatar
Mine as well replavece the clutch while ur there
Old Jun 30, 2012 | 11:37 AM
^^^you don't have si tranny you have dx trans foo ……I would trade for hf trans =] if I wanted mpg
Old Jun 30, 2012 | 11:55 AM
Wtf I never said I did^??
And dx>si for dd
Old Jun 30, 2012 | 12:39 PM
Si ftw
Old Jun 30, 2012 | 12:42 PM
Mpgs FTW
Old Jun 30, 2012 | 01:46 PM
M-benz's Avatar
DX, STD axel have 23 spline
Si axel has 26 spline .
Old Jul 1, 2012 | 08:24 AM
I have both dx and SI tranny. I had an S20 trans as well im not sure what that one is. Honestly I preferred the s20 because the MPGS it gave. Si trans is good for racing but not mpgs.
Old Jul 1, 2012 | 02:23 PM
AH419's Avatar
thanks for the feed back, is the dx 5spd(what is it called?)and is it a cable clutch or hydro?
is it possible to rebuild it and perhaps add an 'over drive' or a fifth gear? i dont know too much about transmissions
What would be the best for increasing acceleration?
Old Jul 2, 2012 | 09:35 AM
Nooch's Avatar
And dx>si for dd
Originally Posted by tonylovesjdmEF9
Si ftw
Mpgs FTW
I've had this conversation with KING before, maybe you too Tony... zc sohc non vtec + si tranny on my daily driver. It's fun and quick. I just baby'd the **** out of it last week (and I mean going 98% freeway for the whole tank of gas, and going 65mph) and I just barely got 34.98mpg.
I haven't driven a car with the dx tranny yet. I would like to though >.>
DX and Si both have exactly the same gearing, the FINAL DRIVE SET is what makes the difference.
http://www.knology.net/~jediklc/gearratiosdseries.htm
Protip
Acceleration: Si transmission
Miles Per Gallon: HF transmission
Mix of both: DX transmission
All these transmissions are 5 speeds. The correct axles/spindles for your setup are another story though. That you'll have to ask someone else about. For some reason the few sets of numbers for splines and **** like that is impossible for me to remember without looking up.
Old Jul 2, 2012 | 11:07 AM
24TEN's Avatar
PHANTOM MENACE
Wrong. CRX HF and Civic STD KNUCKLES use the oddball axles.
FIXED.
Old Jul 2, 2012 | 12:27 PM
Nooch's Avatar
FIXED.
fixed.
I knew something sounded wrong
Old Jul 2, 2012 | 01:35 PM
24TEN's Avatar
PHANTOM MENACE
All good, we knew what you meant .
Old Jul 2, 2012 | 06:02 PM
BIGef's Avatar
Wrong. STD , HF have 23 spline
EX,Lx,Dx,Si have 26
All EF transmission are cable
91crx93civic
Nov 4, 2011 12:58 PM
larryn1369
Apr 27, 2008 08:16 PM
exsinnovation
Sep 20, 2005 11:22 AM
LorenGeist
Aug 13, 2004 11:05 AM
riot
Apr 6, 2002 07:27 AM
