Oil leak from Oil Cooler - but not the block O-ring or Sender Unit
Title says it all.
I have a 93 Honda Accord EX that I'm currently trying to restore for sale and a part of that involves effacing the leaks it has.
I have replaced the o-ring on the back of the oil cooler and oil sender unit/pressure switch since the latter was leaking too, anyway.
But since I've done that and have checked underneath I'm sad to see that there are still a few droplets of oil there.
Here's a pic:
So what I need to know is how do I service the cooler itself?
I have read somewhere that the cooler has more than 1 o-ring. Besides the one on the back/bottom of the cooler there is supposed to be one in the middle. Anyone know of any good links or can write down the procedure for replacing that other o-ring?
Again -- I DON'T HAVE AN ISSUE WITH THE BACK O-RING, THE ONE THAT TYPICALLY CAUSES PROBLEMS. AND MY SENDER UNIT IS NEW AND DOING FINE.
Thank you.
Here's a pic:
Thank you.
Anyone? Or any Honda mechanic here? Anyone with any clue?
This is a very minor leak. It's nothing drastic. But since I went out of my way to replace the oil pan gasket (as you can see above in the pic -- the orange is the new Felpro gasket), and since I replaced the back O-ring and the oil pressure switch, I'm now "all in" and have taken this remaining bit of leakage personally. It needs to go. I'm trying to get this to perfection.
auspilot
Feb 13, 2011 09:31 PM
