GSR rear disk conversion on EG 4 door
Old Jun 29, 2012 | 12:29 PM
EGkevin93's Avatar
Icon3 GSR rear disk conversion on EG 4 door
I am trying to put disk brakes on my EG but the soft lines don't reach the hard lines I had, do i need to take out the hard lines and just run GSR soft lines? or do i need to find a longer hard line? And i am not sure if the GSR hard lines will be long enough .
Old Jun 29, 2012 | 12:34 PM
JuggerNaut-CTR's Avatar
Default Re: GSR rear disk conversion on EG 4 door
I used all gsr lines for my gsr front and rear disk conversion on my hatch
Old Jun 29, 2012 | 12:35 PM
Did you try using the search?...thats what I did when I did my conversion and found everything I needed to know on this forum to do it.
Old Jul 1, 2012 | 03:59 PM
kwijibodavid's Avatar
i beleve u will need the soft lines from an si with rear disks go to autozone just getem for a eg ull be goodwith them bought 30-40 dollars new ull need both driver and pass haha theres a bunny
Old Jul 1, 2012 | 06:11 PM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
So when you say gsr brakes what you really need to say is integra brakes because 04-01 integra brakes are all the same less type r!!! You need to use lines for a integra if you have integra calipers. If I remember correctly the banjo bolt is different between civics and integras.
Tenzo
Suspension & Brakes
Jul 16, 2012 11:17 AM
BlackCivicEX
Apr 28, 2012 04:22 PM
RACE2WARPED
27
Nov 4, 2010 12:36 PM
raytownracer
Jan 29, 2009 03:26 PM
jus_spooln_wicha
May 11, 2007 04:29 PM
