95 sedan with a major oil problem
Old Jun 29, 2012 | 09:45 AM
j4s0n1337's Avatar
Default 95 sedan with a major oil problem
95 sedan lx, stock f22b2 with 265k
So my car has been pretty bad about burning oil ever since i got it about a year ago, but lately it's gotten a lot worse. I changed the headgasket out about 6 months ago and I accidentally put it on the wrong way and i had an oil leak coming from between the head and the block. I got a new head gasket and used some copper spray (head gasket sealer) and it was fine ever since.
Now about 2 weeks ago I noticed my oil consumption has increased, I changed my oil and 600 miles later the light comes on whenever i brake hard or make a sharp right turn. Sometimes when the car is in neutral the oil light will start hyperblinking or the light will be very faint, and there's a very strong smell of burning oil.
I took a look at it this morning and there's an oil leak between the head and the block, same spot where it was before. I checked to see if my oil pressure sensor was leaking at all and it wasn't. I'm thinking maybe my head needs to be milled, but i'm not 100% sure
Any help or input you guys have would be awesome. I plain on doing a h-swap this winter but i need my engine to last until then.
Old Jun 29, 2012 | 01:17 PM
Turbod Fullclip's Avatar
Default Re: 95 sedan with a major oil problem
i had the same problem with my 94 coupe. I since then have installed the H22 but im interested in what the actual problem is. If you want it to last just make sure you put about a quart of oil in about every week depending on the pace of the leak.
Old Jun 29, 2012 | 01:22 PM
j4s0n1337's Avatar
That's what I end up doing, but I'd rather fix the problem than adapt to it. I'm wondering if that head gasket sealer you can pour in the radiator would help this? As a last resort I'll just get the head milled or just get a new one depending on the cost
Old Jun 30, 2012 | 12:51 AM
holmesnmanny's Avatar
I don't even bother with headswaps, i'd rather just put another engine in. Just me.
Old Jun 30, 2012 | 07:40 AM
j4s0n1337's Avatar
Well until I can afford a new engine I'd like to do something about this. Has anyone had this problem before and knows what to do about it?
Old Jun 30, 2012 | 11:46 PM
You can't just put a new headgasket on it. You have to have the head reconditioned.
try cylinderheads.com or just google or search for it.
Old Jul 1, 2012 | 12:34 AM
j4s0n1337's Avatar
I've never had a head reconditioned before and i've never had this problem. I'll take it to my local machine shop sometime this week and get it checked out. I need to replace my valve stem seals as well so i'll just do it all while the head is off.
Old Aug 22, 2012 | 09:50 PM
onebadfntsi's Avatar
check the cam seal,balancer shaft,the o ring at the dizzy ect... thats what was leaking on my 94 accord.
aleon1215
10
Apr 28, 2012 08:21 PM
13g-crx
11
Jul 26, 2007 08:52 AM
Dat1BVtecN
Mar 17, 2007 09:17 PM
Smokeeey420
Sep 26, 2006 09:08 AM
jason190
Mar 31, 2005 08:12 AM
