What's the box under the dash near the clutch/brake pedal?
Old Jun 27, 2012 | 03:25 AM
Teawins21's Avatar
Default What's the box under the dash near the clutch/brake pedal?
I purchased a used accord and for the longest, I couldn't figure out why the Cruise Control would not work. Finally it was digging around under the dash to see if the clutch sensor was broken. I found that the there was a plug that was not connected. It wasn't connect the the metal "ECU looking" thing. After plugged in my cruise control worked fine.
My question is what is that box? what all does it do? It's for me to see that, that box is just relaying the clutch sensor switch to the cruise control unit... I'm wondering what other things would not have worked while that plug was not connected.
Thanks
Old Jun 27, 2012 | 03:32 AM
jdmcertified909's Avatar
Default Re: What's the box under the dash near the clutch/brake pedal?
Thanks
i would like to know what it does too. my 91 honda accord doesnt engage cruise control right away. the light turns on when i hit set. but it takes its time to engage. it has no set time. longest its taken i would say 1 minute
Old Jun 27, 2012 | 04:23 AM
Thepowderblue's Avatar
It sounds like the cruise control computer, It it held in by 2 10mm bolts mounted on a angle? post a picture.The only other thing there is a fuel pump relay.
Old Jun 27, 2012 | 07:18 AM
steadypimpin77's Avatar
Isn't there a main relay next to it also?
Auxient
Apr 1, 2018 07:50 AM
bnewall1
Nov 19, 2013 12:01 AM
girliehonda
Honda Civic (2001 - 2005)
May 5, 2009 01:00 PM
oilguzzler
Nov 21, 2007 08:03 AM
PLude81
Feb 17, 2003 05:34 AM
