B series Injectors capabilities
Old Jun 26, 2012 | 10:28 PM
koolhut's Avatar
Default B series Injectors capabilities
I am currently in the process of swapping a 99 jdm ITR into my 93 Del Sol. I have read conflicting arguments on how much stock 240cc injectors can handle. I originally felt comfortable with keeping them stock but now I am inclined to believe that my car would perform better if I went up to 310cc as the 240cc would be at max duty cycle. I want to know if anyone else is running a similar setup and if so, what size injectors do you use and at what duty cycle do they run.
Specs include AEM hybrid CAI w/ velocity stack, toda replica 4-2-1 header, 2.5" no name straight header back, LW FW, LW crank pulley, no a/c, no p/s. Also going to be running a chipped and street tuned p28. No internal work.
I figured I should be sufficient on stock injectors but want to know what you all think.
Thanks,
Matt
Old Jun 26, 2012 | 10:40 PM
doood's Avatar
been there done that
Default Re: B series Injectors capabilities
you're fine with stock
Old Jun 26, 2012 | 10:41 PM
Dc4LsTeG's Avatar
EK9
Stock injectors are definitely enough for that set up
H-EK22
Feb 22, 2008 11:42 AM
watsvtecEK
Mar 1, 2007 09:43 PM
SD1222
May 20, 2006 07:49 PM
sk8shorty012
Apr 12, 2006 04:12 AM
THMotorsports
May 2, 2005 02:33 PM
