timing issues with 1994 honda civic
Old Jun 26, 2012 | 07:19 PM
ccdc2223's Avatar
Default timing issues with 1994 honda civic
I changed the timing belt on the civic. Putting it back together, I lined up the crank and cam indicators before putting on the belt. After the belt was installed and belt tightened, I rotated the engine by hand and checked that the marks were still good. Car started and ran good, but with a timing light, the timing appeared to be way off.... close to 180 deg on the crank pulley and the service connector at the right kick panel was jumpered. Pulled #1 plug and verified top dead center and checked distributor rotor to verify on #1 plug.... all good. Can anyone help/explain why I can't get the timing on the car?
Old Jun 26, 2012 | 07:41 PM
roc0487's Avatar
Default Re: timing issues with 1994 honda civic
Did you put Cylinder #1 at TDC before you removed the belt? Did you check the rotor to make sure the orientation was Cylinder #1?
Old Jun 26, 2012 | 07:44 PM
Former User's Avatar
Did you forget to re-install the small metal key that holds the crank pulley in the correct fixed position?
Old Jun 26, 2012 | 07:51 PM
roc0487's Avatar
Old Jun 26, 2012 | 08:39 PM
Hondaciv866's Avatar
are you sure you lined up to the right timing marks. I know depending on what engine you have it can be rather confusing. Make sure you know your engine type and you check in a manual where your timing marks are. what year civic do you have and what engine type? for example a d15b7?
Old Jun 27, 2012 | 09:21 AM
gsrjdmej2's Avatar
you lined it up on the single line one the pulley or the three line?
its gotta be on the single line
Vcv079
Apr 17, 2016 04:23 AM
tracy209
Feb 17, 2014 10:03 PM
KenJoTuning
10
May 30, 2012 01:15 PM
daylon1650
Feb 21, 2009 07:22 PM
Bob_760
Jan 30, 2008 02:48 PM
