96 Accord EX "shuddering" at light throttle, 40-45 MPH
Old Jun 26, 2012 | 03:31 PM
toker2's Avatar
10 Year Member
Default 96 Accord EX "shuddering" at light throttle, 40-45 MPH
Hey guys, long time lurker here. I have a 96 F22B1 Accord EX sedan with auto tranny and 170,xxx miles that has what I can best describe as a "shuddering" from the engine and/or tranny under very light throttle (like 5 degrees off idle) at 40-45MPH. It only occurs in D4 and giving it more gas or letting off makes it go away. I have no knowledge of how this car was maintained before I purchased it in March.
So far I have tried many fixes from these very forums, including:
Cleaned EGR valve and passages. All passages were clogged but now spotless
Replaced spark plugs with NGK's (gapped properly).
Drained and filled tranny fluid (3 times) with Genuine Honda fluid and new washer.
Tires balanced and rotated.
Replaced PCV valve
There are no codes in the computer and I have also reset it by pulling the fuse.
This is my first Honda and I am stumped.
Any ideas?
Thanks in advance
Old Jun 26, 2012 | 05:17 PM
v4lu3s's Avatar
RTFM
Default Re: 96 Accord EX "shuddering" at light throttle, 40-45 MPH
what color was the transmission fluid that you replaced? was it still red or was it brown/black or burnt smelling?
Old Jun 26, 2012 | 07:31 PM
toker2's Avatar
10 Year Member
It was brown but not burnt smelling. There was a horrendous amount of shavings on the magnet too. If it matters, I just figured out that the vibration starts occuring around 1800-1900rpm. Torque converter clutch?
Old Jun 26, 2012 | 08:01 PM
CD5B2's Avatar
I read awhile back they fail due to insufficient oil flow through a jet or something to that affect. Does it seem to jerk when you left off the gas going down with a slight grade at all? I noticed mine does that sometimes. Also, did you notice any improvement after getting the egr ports cleaned?
Old Jun 26, 2012 | 08:47 PM
toker2's Avatar
10 Year Member
I don't notice any jerk going down a slight grade. It does downshift at closed throttle going downhill due to the "grade logic." In fact other than what could be this converter clutch problem, the tranny shifts and behaves just fine. No leaks, no rpm flares between gears, no slipping whatsoever.
The only noticable difference after cleaning the EGR ports was smoother acceleration. Then again, I didn't have the telltale CEL indicating they needed cleaning either.
Old Jun 26, 2012 | 08:52 PM
toker2's Avatar
10 Year Member
I'm curious. Since this problem only occurs within a very limited range of throttle angle, could a faulty or out of range TPS cause the converter to lockup at too low of an RPM (aka low line pressure) which would cause the clutch to slip but yet not set a code?
Old Jun 27, 2012 | 10:33 AM
CD5B2's Avatar
Alright just wondering. I don't know if it would be the tps, you could always test it with a voltmeter. I noticed after cleaning my IACV with throttle body cleaner, it rarely jerks now going down a slight grade, you might want to give that a try I think I'm going to try GM synchromesh for my next transmission fluid change, I've been hearing good things about that. Good luck!
Old Jun 27, 2012 | 01:39 PM
toker2's Avatar
10 Year Member
Yeah, I was going to do the IACV next since even on hot days >90F the engine idles at 1500RPM until warmed up. From what I've read that behavior is normal... in the winter. Certainly can't be correct during this heatwave the midwest is experiencing. Thanks for all the input I've received so far. If anyone has further suggestions, I'd love to read them.
Old Jun 27, 2012 | 02:29 PM
holmesnmanny's Avatar
Yeah it could be TPS. Just do a search for how to test and calibrate it, there are threads about it.
Old Jun 27, 2012 | 03:27 PM
Jmb106jr's Avatar
here is a link for the TPS https://honda-tech.com/forums/honda-accord-1990-2002-2/1993-accord-dx-tps-removal-2822004/
Old Jun 27, 2012 | 03:52 PM
toker2's Avatar
10 Year Member
Thanks Jmb106jr! I just got back from buying an analog meter. Going to test it now.
Old Jun 27, 2012 | 04:58 PM
toker2's Avatar
10 Year Member
Well, the TPS test results were mixed. The meter showed .5 volts at closed throttle, made a smooth clean sweep as I opened the throttle but stopped at ~4.15 volts at WOT. Isn't it supposed to go to 4.5 volts at WOT? I thought they usually developed a flat spot and the meter would jump around when within that range. Never heard of one being within range everywhere but at WOT. Still stumped.
Old Nov 27, 2012 | 02:13 AM
toker2's Avatar
10 Year Member
Not to bring up an old thread, but I wanted to let everyone know that the problem is fixed.
I'm not sure what happened, but over the last few months the shuddering has slowly disappeared to the point where it is no longer noticeable. My best guess is that a previous owner or mechanic put non-spec fluid in the transmission which worked its way into the clutch plates and it simply took a while for the Honda ATF to displace it.
Thanks again to all those who offered up their ideas.
Old Jan 2, 2013 | 12:19 PM
drgerry's Avatar
toker2,
thanks for the upedate. I'm a new Honda owner with a 96 Accord. I'm getting that shutter a speed as well. I also noticed that the torque converter was locking-unlocking (and firmly) with very little throttle movement, usually at highway speeds.
Did you do the drain/fill 3x routine before adding Honda Z1 fluid?
Old Jan 3, 2013 | 11:49 PM
toker2's Avatar
10 Year Member
Yes, I drained it (about 3 quarts came out) and refilled with Genuine Honda fluid. Waited a week and repeated the procedure. Then waited another 2 weeks and did it a third time. It took 2-3 months after that final drain/fill for me to notice an improvement. Good luck!
dougaccordwagon
Transmission & Drivetrain
Jul 19, 2016 09:55 PM
laloquera916
Mar 14, 2011 01:35 PM
andres2283
Mar 9, 2009 08:07 PM
nickoz
Jan 16, 2008 08:53 PM
brpracer
Oct 13, 2005 01:53 PM
