DA Brake Master Cylinder Swap
So my EF's master cylinder is slowly leaking brake fluid and im sick of bleeding my brakes every other week. So ive decided to swap in a DA master cylinder, my question is:
Do i need to replace the brake booster too or just the master cylinder?
I've done a search and i saw a few threads but theres a discrepancy on if a 1" 90-93 DB integra master cylinder would bolt up to a ED7 brake booster. So would the DB master cylinder bolt up? and that being said would a DA bolt up?
Like i said i read like 3 threads and each of them said something different.
Im in the same kinda boat as you but a long time ago I picked up the non abs master and booster from the da 15/16.... gonna swap them in this weekend since my pedal isn't feeling to great lately.
I know forsure from alot of people who said the 1inch master and booster will not work unless I was ton differently its for abs cars only..... but for just for a 1inch master to work with the stock booster I"m not even sure. I really don't see how that would work,
id rather just go with the 15/16 master/booster and be done with it or just get the 1inch booster if I was wrong to mount to your 1inch master....
I think one of the fittings is a different size but if you change and re flare it but a 15/16 master is a easier swap
Why not just replace with one made for your car instead of the DA one?
The oversized MC isn't right for your brake system unless you have done a front brake swap.
Well i have the rear hubs for a disc swap and i have the discs from a DA so im GOING to do it but at the moment im about to put in an LS/VTEC so that takes presidence in my wallet. I just wanted to do it while i got the engine out so its easier.
DC5_lov3r
Apr 16, 2008 07:28 PM
adrian1281
Aug 23, 2003 09:43 PM
